I am getting the following error when compiling for the IOS simulator. But everything is fine when compiling for the iPhone device.
ld: warning: ignoring file /Users/glenn/Software/Development/LMIOS-LS/lc/smartconfig/libFTC_DEBUG.a, missing required architecture i386 in file /Users/glenn/Software/Development/LMIOS-LS/lc/smartconfig/libFTC_DEBUG.a (2 slices)
ld: warning: ignoring file /Users/glenn/Software/Development/LMIOS-LS/lc/smartconfig/libFTC_RELEASE.a, missing required architecture i386 in file /Users/glenn/Software/Development/LMIOS-LS/lc/smartconfig/libFTC_RELEASE.a (2 slices)
Undefined symbols for architecture i386:
"_OBJC_CLASS_$_FirstTimeConfig", referenced from:
objc-class-ref in CC3xMainViewController.o
objc-class-ref in CC3xUtility.o
ld: symbol(s) not found for architecture i386
clang: error: linker command failed with exit code 1 (use -v to see invocation)
I found the following discussion which states this often happens when the external library has not been compiled for both the device and simulator.
http://stackoverflow.com/questions/15659631/ignoring-file-path-missing-required-architecture-i386-in-file
If this is the case, is there a universal library available so I can return to using the Simulator which enables me to test various versions of iPhone and iPad.
I have also seen the following discussion, but my profiles seem fine, everything else works, including other external libraries - http://e2e.ti.com/support/low_power_rf/f/851/t/295269.aspx
If I shouldn't be seeing this message, please also let me know so I can return to trying to solve the problem.
Glenn.
