What does the channel space setting influence for?
I want to set the channel space setting as 200kHz for 400kHz actual bandwidth system, and I will use the alternate channels.
Also, CC2500 can communicate each other with the 200kHz channel space setting.
However, in the above case, should I set the channel space as 400kHz?
Best Regards.
Nomoto
