hi
CC3100 not connected. it only needs id and password, not a client certificate. when connects to wifi in window, linux and android, ca certificate's not used.
wpa enterprise spec.
Security : WPA & WPA2 Enterprise
Authentication : Protected EAP (PEAP)
CA certificate is not needed
PEAP version : peap0
Inner authentication : MSCHAPv2
Username and Password are correct.
Ca certificate's been needed in sdk document , which one should I use?
source code
#define EAP_SSID_NAME "my_ssid" #define EAP_USER_NAME "my_id" #define EAP_PASS_KEY "my_pass" #define EAP_SEC_METHOD SL_ENT_EAP_METHOD_PEAP0_MSCHAPv2 #define EAP_SEC_TYPE SL_SEC_TYPE_WPA_ENT SlSecParams_t secParams; SlSecParamsExt_t eapParams; secParams.Key = EAP_PASS_KEY; secParams.KeyLen = strlen(EAP_PASS_KEY); secParams.Type = EAP_SEC_TYPE; eapParams.EapMethod = EAP_SEC_METHOD; eapParams.User = EAP_USER_NAME; eapParams.UserLen = strlen(EAP_USER_NAME); eapParams.AnonUserLen = 0; sl_WlanConnect(EAP_SSID_NAME, strlen(EAP_SSID_NAME), NULL, &secParams, &eapParams);
kaien
