I am not able to resize the radio tool window and therefore I can not see everything or access everything in the window.
The "Information" box is not fully visible.
The right half of the tab is completely cut off as id the bottom of the tab.
Hi Kas,
Can you please share your system font settings?
We'll try to fix this for the next release. For the time being, can you please try the application on another PC and see if you still experience the same issue? The radio tool has been tested with default, 125%, and 150% text size and they all seem to work fine.
