Hey guys,
I am trying to interface an SD card with the Launchpad, however, when I run the sdhost example provided in the SDK and check the terminal, it gives the error "failed to initialize the card. See if the card is properly inserted."
I have tried: https://www.sparkfun.com/products/12941
As well as this: http://www.adafruit.com/products/254
I tried using the pinout from the datasheet as well as the pinout from the example doc file "CC32xx SDHost.pdf"
