Hi Experts,
I would like to change Base Address for my application and it works fine from debugger. It does not work when I flash it as mcuimg.bin and change SOP jumper to boot directly.
Following gcc linker configuration works fine for blinky example
SRAM (rwx) : ORIGIN = 0x20004000, LENGTH = 0x00030000
and following doesn't work though it works from debugger.
SRAM (rwx) : ORIGIN = 0x20005000, LENGTH = 0x0002F000
The reason I believe that gdb/ccs knows where to jump after loading image in SRAM but TI bootloader seems to expect image to be present only at 0x20004000. Is this a hard limit or there is any way around to tell TI bootloader where to find image.
