Smartconfig provisioning is not working with out of box example. I am using latest service pack 1.0.0.1. Please find the complete details below as I tried almost all the suggestion I could find in this forum related to similar problem reported earlier.
- Hardware: CC3200 LAUNCHXL Rev 3.2
- Formated SFlash from Uniflesh
- Flashed Service Pack 1.0.0.1
- Programmed out of box files based on out_of_box.ucf
- When VCC Pin58 Jumper connected. Device is in AP mode and it works fine. I can connect http://mysimplelink.net and see pages
- When Jumper removed Device is in station mode and I try with Android TI Simplelink Wifi Starter application. Provided my ssid and password and pressed start. After completing, application says no new device found. LED is red. Tried several time by rebooting again and again with no success
- There is no existing device previously connected in Wifi Starter application. This is first time Wifi starter application is downloaded from Google Play Store. Android version 4.4 (kitkat). Phone hardware: MotoE
- My Wifi router (AP) is running using 2.4GHz band
- I can connect to same EP using getting_started_with_wlan_station successfully by providing my ssid/password/wep setting. This means device in station mode can connect to my AP. Only problem is with smartconfig provisioning
- I debugged out of box application and installed breakpoint sl_WlanEvtHdlr() to see what events are reported to application.
- When I start android app with ssid and password sl_WlanEvtHdlr() function hits with event SL_WLAN_SMART_CONFIG_START_EVENT
- After that no further event is reported (sl_WlanEvtHdlr() never hit again). I was expecting that SL_WLAN_CONNECT_EVENT will be reported fir successful connection. Interestingly SL_WLAN_SMART_CONFIG_STOP_EVENT is also not reported. I thought that it will be reported when progress war on android app finishes and it says No new Device Found.
Looking for your expert comments to resolve smartconfig problem.
