I started httpserver example, connect to my PC to launchpad, go to mysimplelink.net, but there is not a topic demo, as you can see on picture. Problem?
Srki
Hi Markel,
it still didn't help. I can connect with my browser. I ping my acess point from mysimlelink.net and works fine. But I still do not have a topic demo. Do you have idea?
Srki
Using Uniflash, format your CC3200 with Secure and Alert option unchecked. Then load service pack.
Then try httpserver again and see if you get the same results.
- kel
Hi Srki,
Most likely there is another html page already loaded in the sFlash, and you are not overwriting that file with the new html for the http server. Let's try to reformat your device, and load the http files.
Do the following.
1. Reformat the device
2. Load the service pack.
3. Open the http server configuration file. this one ends with ".ucf". You will find this file in this directory: C:\ti\CC3200SDK_1.0.0\cc3200-sdk\example\httpserver\html
Then try to run the demo again.
Hi Srki,
I am closing this thread. Let us know if you have any other related issue, by opening a new thread, and linking to this one.
