Unable to install pin mux utility in windows 8.1.
Hi John,
Could you provide some more details on what happens?
Could you also check if an installer log was created? If you open a Windows Explorer and type %TEMP% in the address bar, it will take you to your temp folder. The installer log is named "bitrock_installer_<process_id>.log". If you sort the files by creation date, it would easier to find. If there is a log, please attach it here.
Thanks very much, Andy:
For some reason the setup file was downloaded as a "396" file and not an "exe" file. Apparantly this file type is accessed by windows explorer.
Anyway I tried renaming it as pinmux.exe and it was able to install the utility correctly in windows 8.1.
John
