All,
We are introducing a new SimpleLink Studio application that adds the CC3100 Device Location on Google MAPs. [Currently we are supporting CC3100 only]
Try these links [If you run the tests you will be able to see your own device MAC address on the MAP]
3288.MyLocation.ziphttps://maps.google.com/maps?f=q&hl=en&q=https://sites.google.com/site/simplelinklocationmap/sl_location.kml
[The above link shows the list of devices - verify that the time has been updated]
We would like to ask you to run this application and help us build a nice map of all SimpleLink CC3100 devices around the world.
Enclosed is MyLocation.exe utility that is based on the SimpleLink Studio.
All you need to do is the following:
- Connect your Booster Pack board with CC3100R1 OR XCC3100HZ + Emulation board to your PC
- Run MyLocation.exe
- You will need to specify the AP info
- i.e. MyLocation.exe SSID_NAME SEC_TYPE SEC_KEY
- The application will connect to the AP (based on the provided information)
- The locations will be collected in a Drop Box and can be shown on Google MAP (refresh every few minutes)
- The location is based on the Internet source provider and mobile hotspot shows different location at all
If the test fail for any reason please send the information below:
- AP module (FW and HW version if possible)
- CC3100 Silicon version
- Security Type
- Location in the world
- Txt Log file – stored in the directory of the application
The test run time is about 15Sec.
How to operate the application -
Arguments:
- AP SSID(string)
- Security Type [0-Open, 1-WEP, 2-WPA]
- Security Key(string)
- i.e. MyLocation.exe APAPAP 2 1234567890
[Please login to the forum in order to download the archive file]
