Hi guys,
I want some explanation about this code from the HTTP server example on CC3200.Can anybody help me with it
void SimpleLinkHttpServerCallback(SlHttpServerEvent_t *pSlHttpServerEvent,
SlHttpServerResponse_t *pSlHttpServerResponse)
UINT8 strLenVal = 0;
switch (pSlHttpServerEvent->Event)
case SL_NETAPP_HTTPGETTOKENVALUE:
UINT8 status, *ptr;
ptr = pSlHttpServerResponse->ResponseData.token_value.data;
pSlHttpServerResponse->ResponseData.token_value.len = 0;
if(memcmp(pSlHttpServerEvent->EventData.httpTokenName.data, GET_token,
strlen((const char *)GET_token)) == 0)
status = GPIO_IF_LedStatus(MCU_RED_LED_GPIO);
strLenVal = strlen(LED1_STRING);
memcpy(ptr, LED1_STRING, strLenVal);
ptr += strLenVal;
pSlHttpServerResponse->ResponseData.token_value.len += strLenVal;
if(status & 0x01)
strLenVal = strlen(LED_ON_STRING);
memcpy(ptr, LED_ON_STRING, strLenVal);
ptr += strLenVal;
else
strLenVal = strlen(LED_OFF_STRING);
memcpy(ptr, LED_OFF_STRING, strLenVal);
ptr += strLenVal;
status = GPIO_IF_LedStatus(MCU_GREEN_LED_GPIO);
strLenVal = strlen(LED2_STRING);
memcpy(ptr, LED2_STRING, strLenVal);
ptr += strLenVal;
if(status & 0x01)
ptr += strLenVal;
else
ptr += strLenVal;
*ptr = '\0';
break;
case SL_NETAPP_HTTPPOSTTOKENVALUE:
UINT8 led;
UINT8 *ptr = pSlHttpServerEvent->EventData.httpPostData.token_name.data;
if(memcmp(ptr, POST_token, strlen((const char *)POST_token)) == 0)
ptr = pSlHttpServerEvent->EventData.httpPostData.token_value.data;
strLenVal = strlen(LED_STRING);
if(memcmp(ptr, LED_STRING, strLenVal) != 0)
break;
ptr += strLenVal;
led = *ptr;
ptr += strLenVal;
if(led == '1')
if(memcmp(ptr, LED_ON_STRING, strLenVal) == 0)
GPIO_IF_LedOn(MCU_RED_LED_GPIO);
else
GPIO_IF_LedOff(MCU_RED_LED_GPIO);
else if(led == '2')
GPIO_IF_LedOn(MCU_GREEN_LED_GPIO);
else
GPIO_IF_LedOff(MCU_GREEN_LED_GPIO);
break;
default:
break;
