I wanted to ask if there are any differences when programming the CC32000 module compared to the LaunchPad. More specifically if anything needs to be loaded into the serial flash, or if it comes "pre-loaded".
I currently try to run some programs on the module, that I developed on the Launchpad and run into problems. My SPI examples work fine, however when I try to run WiFi test code (including the SDK examples) I get the following error when executing sl_Start:
Invalid ACK 0x6 in JTAG-DP transaction
Polling target cc3200.cpu failed, GDB will be halted. Polling again in 100ms
[Remote target] #1 stopped.
I attach my gdbinit and cc3200.cpu file.
Thank you for your time,
Severin
# # Droidifi OpenOCD config for TI CC3200-LP V3.2 # # http://www.droidifi.com # # Copyright Droidifi LLC 2013, 2014 All rights reserved # #***************************************************************************** # # # # # Redistribution and use in source and binary forms, with or without # modification, are permitted provided that the following conditions # are met: # # Redistributions of source code must retain the above copyright # notice, this list of conditions and the following disclaimer. # # Redistributions in binary form must reproduce the above copyright # notice, this list of conditions and the following disclaimer in the # documentation and/or other materials provided with the # distribution. # # Neither the name of Texas Instruments Incorporated nor the names of # its contributors may be used to endorse or promote products derived # from this software without specific prior written permission. # # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS # "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT # LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR # A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT # OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, # SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT # LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, # DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY # THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE # OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. # #***************************************************************************** interface ftdi ftdi_device_desc "USB <-> JTAG/SWD" ftdi_vid_pid 0x0451 0xc32a ftdi_layout_init 0x00a8 0x00eb ftdi_layout_signal nSRST -noe 0x0020 adapter_khz 1000 set _ENDIAN little if { [info exists CHIPNAME] } { set _CHIPNAME $CHIPNAME } else { set _CHIPNAME cc3200 } source [find target/icepick.cfg] if { [info exists DAP_TAPID] } { set _DAP_TAPID $DAP_TAPID } else { set _DAP_TAPID 0x0b97c02f } jtag newtap $_CHIPNAME dap -irlen 4 -ircapture 0x1 -irmask 0xf -expected-id $_DAP_TAPID -disable # APP m4 jtag configure $_CHIPNAME.dap -event tap-enable "icepick_c_tapenable $_CHIPNAME.jrc 0" # ICEpick-C (JTAG route controller) if { [info exists JRC_TAPID] } { set _JRC_TAPID $JRC_TAPID } else { set _JRC_TAPID $_DAP_TAPID } jtag newtap $_CHIPNAME jrc -irlen 6 -ircapture 0x1 -irmask 0x3f -expected-id $_JRC_TAPID -ignore-version # jtag configure auto0.jrc -event post-reset "runtest 100" jtag configure $_CHIPNAME.jrc -event setup "jtag tapenable $_CHIPNAME.dap" jtag configure $_CHIPNAME.jrc -event post-reset "runtest 100" set _TARGETNAME $_CHIPNAME.cpu target create $_CHIPNAME.cpu cortex_m -endian little -chain-position $_CHIPNAME.dap $_CHIPNAME.cpu configure -work-area-phys 0x20000000 -work-area-size 0x30000 -work-area-backup 0 -coreid 0 source [find mem_helper.tcl] $_TARGETNAME configure -event gdb-attach { # cc3200_dbginit $_TARGETNAME # cortex_m dbginit halt } $_TARGETNAME configure -event "reset-start" { adapter_khz 1000 } $_TARGETNAME configure -event "reset-assert" { global _CHIPNAME # assert warm system reset through ICEPick icepick_c_wreset $_CHIPNAME.jrc } # Run this to enable invasive debugging. This is run automatically in the # reset sequence. proc cc3200_dbginit {target} { cortex_m dbginit }
#***************************************************************************** # gdbinit # # Initilization script for GDB for ARM # # Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/ # # # Redistribution and use in source and binary forms, with or without # modification, are permitted provided that the following conditions # are met: # # Redistributions of source code must retain the above copyright # notice, this list of conditions and the following disclaimer. # # Redistributions in binary form must reproduce the above copyright # notice, this list of conditions and the following disclaimer in the # documentation and/or other materials provided with the # distribution. # # Neither the name of Texas Instruments Incorporated nor the names of # its contributors may be used to endorse or promote products derived # from this software without specific prior written permission. # # THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS # "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT # LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR # A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT # OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, # SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT # LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, # DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY # THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT # (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE # OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. # #***************************************************************************** #***************************************************************************** #Connect To the tartget using OpenOCD #***************************************************************************** target remote | /home/severin/uni/ocd/bin/openocd -c "gdb_port pipe; log_output config/openocd.log" -f config/cc3200.cfg #***************************************************************************** # Load the binary #***************************************************************************** load #***************************************************************************** # Initialize the SP and PC values from the application's # vector table #***************************************************************************** set $sp = g_pfnVectors[0] set $pc = g_pfnVectors[1] #***************************************************************************** # Set break point at main and run to main #***************************************************************************** break main continue
