Hello Team,
I am using two cc1310 evms running this example code :
I've gotten the example code working and have customized an application to transmit data. My transmit application works properly when it's running through the debugger, but doesn't work when I reset the board. Is there a common fix for that behavior?
When I run the uartecho demo it works correctly both when connected to the debugger and when the debug session is terminated and the board is reset.
Thank you,
Yiding
