Hi
For the transmission operation in the case of using the diversity of the CC1200.
Storing an antenna selected by the diversity.
Data(ACK, etc.) to be transmitted next time, is outputted from the antenna selected to the receiving immediately before.
Correct?
【Experimental result】
ACK is output in the last selected antenna.
Otherwise ANT1.
Attach the setting register value.
R:reg[0x0000] dat[0x06] name[IOCFG3] -->PKT_SYNC_RXTX(06) R:reg[0x0001] dat[0x26] name[IOCFG2] -->MARC_2PIN_STATUS[0](38) R:reg[0x0002] dat[0x30] name[IOCFG1] -->HIGHZ(48) R:reg[0x0003] dat[0x24] name[IOCFG0] -->ANTENNA_SELECT(36) R:reg[0x0004] dat[0x90] name[SYNC3] R:reg[0x0005] dat[0x4e] name[SYNC2] R:reg[0x0006] dat[0x90] name[SYNC1] R:reg[0x0007] dat[0x4e] name[SYNC0] R:reg[0x0008] dat[0x48] name[SYNC_CFG1] R:reg[0x0009] dat[0x2a] name[SYNC_CFG0] R:reg[0x000a] dat[0x48] name[DEVIATION_M] R:reg[0x000b] dat[0x0c] name[MODCFG_DEV_E] R:reg[0x000c] dat[0x4b] name[DCFILT_CFG] R:reg[0x000d] dat[0x31] name[PREAMBLE_CFG1] R:reg[0x000e] dat[0x9a] name[PREAMBLE_CFG0] R:reg[0x000f] dat[0xd8] name[IQIC] R:reg[0x0010] dat[0x07] name[CHAN_BW] R:reg[0x0011] dat[0x42] name[MDMCFG1] R:reg[0x0012] dat[0x05] name[MDMCFG0] R:reg[0x0013] dat[0xa4] name[SYMBOL_RATE2] R:reg[0x0014] dat[0x7a] name[SYMBOL_RATE1] R:reg[0x0015] dat[0xe1] name[SYMBOL_RATE0] R:reg[0x0016] dat[0x2d] name[AGC_REF] R:reg[0x0017] dat[0xc0] name[AGC_CS_THR] R:reg[0x0018] dat[0xd4] name[AGC_GAIN_ADJUST] R:reg[0x0019] dat[0xb1] name[AGC_CFG3] R:reg[0x001a] dat[0x20] name[AGC_CFG2] R:reg[0x001b] dat[0x52] name[AGC_CFG1] R:reg[0x001c] dat[0xc0] name[AGC_CFG0] R:reg[0x001d] dat[0x05] name[FIFO_CFG] R:reg[0x001e] dat[0x00] name[DEV_ADDR] R:reg[0x001f] dat[0x0b] name[SETTLING_CFG] R:reg[0x0020] dat[0x12] name[FS_CFG] R:reg[0x0021] dat[0x08] name[WOR_CFG1] R:reg[0x0022] dat[0x21] name[WOR_CFG0] R:reg[0x0023] dat[0x00] name[WOR_EVENT0_MSB] R:reg[0x0024] dat[0x00] name[WOR_EVENT0_LSB] R:reg[0x0025] dat[0x00] name[RXDCM_TIME] R:reg[0x0026] dat[0x2c] name[PKT_CFG2] R:reg[0x0027] dat[0x45] name[PKT_CFG1] R:reg[0x0028] dat[0x40] name[PKT_CFG0] R:reg[0x0029] dat[0x3f] name[RFEND_CFG1] R:reg[0x002a] dat[0x35] name[RFEND_CFG0] R:reg[0x002b] dat[0x7f] name[PA_CFG1] R:reg[0x002c] dat[0x56] name[PA_CFG0] R:reg[0x002d] dat[0x0f] name[ASK_CFG] R:reg[0x002e] dat[0x00] name[PKT_LEN] R:reg[0x2f00] dat[0x1c] name[IF_MIX_CFG] R:reg[0x2f01] dat[0x20] name[FREQOFF_CFG] R:reg[0x2f02] dat[0x03] name[TOC_CFG] R:reg[0x2f03] dat[0x00] name[MARC_SPARE] R:reg[0x2f04] dat[0x00] name[ECG_CFG] R:reg[0x2f05] dat[0x02] name[MDMCFG2] R:reg[0x2f06] dat[0x01] name[EXT_CTRL] R:reg[0x2f07] dat[0x00] name[RCCAL_FINE] R:reg[0x2f08] dat[0x00] name[RCCAL_COARSE] R:reg[0x2f09] dat[0x00] name[RCCAL_OFFSET] R:reg[0x2f0a] dat[0x00] name[FREQOFF1] R:reg[0x2f0b] dat[0x00] name[FREQOFF0] R:reg[0x2f0c] dat[0x5c] name[FREQ2] R:reg[0x2f0d] dat[0x9c] name[FREQ1] R:reg[0x2f0e] dat[0x29] name[FREQ0] R:reg[0x2f0f] dat[0x02] name[IF_ADC2] R:reg[0x2f10] dat[0xee] name[IF_ADC1] R:reg[0x2f11] dat[0x10] name[IF_ADC0] R:reg[0x2f12] dat[0x04] name[FS_DIG1] R:reg[0x2f13] dat[0x55] name[FS_DIG0] R:reg[0x2f14] dat[0x00] name[FS_CAL3] R:reg[0x2f15] dat[0x20] name[FS_CAL2] R:reg[0x2f16] dat[0x40] name[FS_CAL1] R:reg[0x2f17] dat[0x0e] name[FS_CAL0] R:reg[0x2f18] dat[0x15] name[FS_CHP] R:reg[0x2f19] dat[0x03] name[FS_DIVTWO] R:reg[0x2f1a] dat[0x00] name[FS_DSM1] R:reg[0x2f1b] dat[0x33] name[FS_DSM0] R:reg[0x2f1c] dat[0xff] name[FS_DVC1] R:reg[0x2f1d] dat[0x17] name[FS_DVC0] R:reg[0x2f1e] dat[0x00] name[FS_LBI] R:reg[0x2f1f] dat[0x00] name[FS_PFD] R:reg[0x2f20] dat[0x6e] name[FS_PRE] R:reg[0x2f21] dat[0x1c] name[FS_REG_DIV_CML] R:reg[0x2f22] dat[0xac] name[FS_SPARE] R:reg[0x2f23] dat[0x18] name[FS_VCO4] R:reg[0x2f24] dat[0x00] name[FS_VCO3] R:reg[0x2f25] dat[0x6b] name[FS_VCO2] R:reg[0x2f26] dat[0x9c] name[FS_VCO1] R:reg[0x2f27] dat[0xb5] name[FS_VCO0] R:reg[0x2f28] dat[0x00] name[GBIAS6] R:reg[0x2f29] dat[0x02] name[GBIAS5] R:reg[0x2f2a] dat[0x00] name[GBIAS4] R:reg[0x2f2b] dat[0x00] name[GBIAS3] R:reg[0x2f2c] dat[0x10] name[GBIAS2] R:reg[0x2f2d] dat[0x00] name[GBIAS1] R:reg[0x2f2e] dat[0x00] name[GBIAS0] R:reg[0x2f2f] dat[0x09] name[IFAMP] R:reg[0x2f30] dat[0x01] name[LNA] R:reg[0x2f31] dat[0x01] name[RXMIX] R:reg[0x2f32] dat[0x0e] name[XOSC5] R:reg[0x2f33] dat[0xa0] name[XOSC4] R:reg[0x2f34] dat[0x03] name[XOSC3] R:reg[0x2f35] dat[0x04] name[XOSC2] R:reg[0x2f36] dat[0x03] name[XOSC1] R:reg[0x2f37] dat[0x00] name[XOSC0] R:reg[0x2f38] dat[0x00] name[ANALOG_SPARE] R:reg[0x2f39] dat[0x00] name[PA_CFG3] R:reg[0x2f3f] dat[0x00] name[IRQ0M] R:reg[0x2f40] dat[0x80] name[IRQ0F] R:reg[0x2f64] dat[0x00] name[WOR_TIME1] R:reg[0x2f65] dat[0x00] name[WOR_TIME0] R:reg[0x2f66] dat[0x00] name[WOR_CAPTURE1] R:reg[0x2f67] dat[0x00] name[WOR_CAPTURE0] R:reg[0x2f68] dat[0x00] name[BIST] R:reg[0x2f69] dat[0x00] name[DCFILTOFFSET_I1] R:reg[0x2f6a] dat[0x00] name[DCFILTOFFSET_I0] R:reg[0x2f6b] dat[0x00] name[DCFILTOFFSET_Q1] R:reg[0x2f6c] dat[0x00] name[DCFILTOFFSET_Q0] R:reg[0x2f6d] dat[0x00] name[IQIE_I1] R:reg[0x2f6e] dat[0x00] name[IQIE_I0] R:reg[0x2f6f] dat[0x00] name[IQIE_Q1] R:reg[0x2f70] dat[0x00] name[IQIE_Q0] R:reg[0x2f71] dat[0xb6] name[RSSI1] R:reg[0x2f72] dat[0x43] name[RSSI0] R:reg[0x2f73] dat[0x41] name[MARCSTATE] R:reg[0x2f74] dat[0x00] name[LQI_VAL] R:reg[0x2f75] dat[0xff] name[PQT_SYNC_ERR] R:reg[0x2f76] dat[0x00] name[DEM_STATUS] R:reg[0x2f77] dat[0xfe] name[FREQOFF_EST1] R:reg[0x2f78] dat[0xf6] name[FREQOFF_EST0] R:reg[0x2f79] dat[0x27] name[AGC_GAIN3] R:reg[0x2f7a] dat[0xd1] name[AGC_GAIN2] R:reg[0x2f7b] dat[0x00] name[AGC_GAIN1] R:reg[0x2f7c] dat[0x3f] name[AGC_GAIN0] R:reg[0x2f7d] dat[0x00] name[CFM_RX_DATA_OUT] R:reg[0x2f7e] dat[0x00] name[CFM_TX_DATA_IN] R:reg[0x2f7f] dat[0x30] name[ASK_SOFT_RX_DATA] R:reg[0x2f80] dat[0x7f] name[RNDGEN] R:reg[0x2f81] dat[0x00] name[MAGN2] R:reg[0x2f82] dat[0x00] name[MAGN1] R:reg[0x2f83] dat[0x08] name[MAGN0] R:reg[0x2f84] dat[0x03] name[ANG1] R:reg[0x2f85] dat[0x35] name[ANG0] R:reg[0x2f86] dat[0x02] name[CHFILT_I2] R:reg[0x2f87] dat[0x00] name[CHFILT_I1] R:reg[0x2f88] dat[0x00] name[CHFILT_I0] R:reg[0x2f89] dat[0x00] name[CHFILT_Q2] R:reg[0x2f8a] dat[0x00] name[CHFILT_Q1] R:reg[0x2f8b] dat[0x00] name[CHFILT_Q0] R:reg[0x2f8c] dat[0x00] name[GPIO_STATUS] R:reg[0x2f8d] dat[0x01] name[FSCAL_CTRL] R:reg[0x2f8e] dat[0x00] name[PHASE_ADJUST] R:reg[0x2f8f] dat[0x20] name[PARTNUMBER] R:reg[0x2f90] dat[0x11] name[PARTVERSION] R:reg[0x2f91] dat[0x00] name[SERIAL_STATUS] R:reg[0x2f92] dat[0x11] name[MODEM_STATUS1] R:reg[0x2f93] dat[0x00] name[MODEM_STATUS0] R:reg[0x2f94] dat[0x02] name[MARC_STATUS1] R:reg[0x2f95] dat[0x00] name[MARC_STATUS0] R:reg[0x2f96] dat[0x00] name[PA_IFAMP_TEST] R:reg[0x2f97] dat[0x00] name[FSRF_TEST] R:reg[0x2f98] dat[0x00] name[PRE_TEST] R:reg[0x2f99] dat[0x00] name[PRE_OVR] R:reg[0x2f9a] dat[0x00] name[ADC_TEST] R:reg[0x2f9b] dat[0x0b] name[DVC_TEST] R:reg[0x2f9c] dat[0x40] name[ATEST] R:reg[0x2f9d] dat[0x00] name[ATEST_LVDS] R:reg[0x2f9e] dat[0x00] name[ATEST_MODE] R:reg[0x2f9f] dat[0x00] name[XOSC_TEST1] R:reg[0x2fa0] dat[0x00] name[XOSC_TEST0] R:reg[0x2fa1] dat[0x00] name[AES] R:reg[0x2fa2] dat[0x00] name[MDM_TEST] R:reg[0x2fd2] dat[0x00] name[RXFIRST] R:reg[0x2fd3] dat[0x00] name[TXFIRST] R:reg[0x2fd4] dat[0x00] name[RXLAST] R:reg[0x2fd5] dat[0x00] name[TXLAST] R:reg[0x2fd6] dat[0x00] name[NUM_TXBYTES] R:reg[0x2fd7] dat[0x00] name[NUM_RXBYTES] R:reg[0x2fd8] dat[0x0f] name[FIFO_NUM_TXBYTES] R:reg[0x2fd9] dat[0x00] name[FIFO_NUM_RXBYTES]
Kozo
