hi
I'm learning CC1350 now, below is the hardware:
and the software is :tirtos_cc13xx_cc26xx_2_20_00_06\examples\IAR\CC1350_LAUNCHXL\rfPacketTx.
I used spectrum analyzer to test CC1350's TX POWER, but the result is -60dBm, apparently it's not correct, but I check the code setting, the RF SW Switch defaults to sub-1GHz path and the External RF Switch is powered on by default. It's wired. And I tried 3 modules at 868M or 433M, the result is the same.
So, any other settings need to midified?
Thanks!
