Other Parts Discussed in Thread: CC1310
Tool/software: TI-RTOS
I want to use a Watchdog to reset my device. For Testing, I combined the uartecho and the watchdog example from the simplelink_cc13x0_sdk_1_30_00_06.
If I use a Watchdog callback like in the watchdog example, everything works as expected. But since I want to use the Watchdog for resetting, I switched removed the callback and set the resetMode to ON. Now I would expect that the Device performes a reset when the Watchdog expires, so I would see the Startup Message again. But nothing is happen.
This is the Code I used:
/* * Copyright (c) 2016, Texas Instruments Incorporated * All rights reserved. * * Redistribution and use in source and binary forms, with or without * modification, are permitted provided that the following conditions * are met: * * * Redistributions of source code must retain the above copyright * notice, this list of conditions and the following disclaimer. * * * Redistributions in binary form must reproduce the above copyright * notice, this list of conditions and the following disclaimer in the * documentation and/or other materials provided with the distribution. * * * Neither the name of Texas Instruments Incorporated nor the names of * its contributors may be used to endorse or promote products derived * from this software without specific prior written permission. * * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */ /* * ======== watchdog.c ======== */ #include <unistd.h> #include <stdbool.h> #include <stdint.h> #include <stddef.h> /* TI-RTOS Header files */ #include <ti/drivers/PIN.h> #include <ti/drivers/Watchdog.h> /* Example/Board Header files */ #include "Board.h" /* Global memory storage for a PIN_Config table */ static PIN_State ledPinState; static PIN_State buttonPinState; /* Pin driver handles */ static PIN_Handle ledPinHandle; static PIN_Handle buttonPinHandle; /* * Application LED pin configuration table: * - Board_PIN_LED0 is initially off. */ PIN_Config ledPinTable[] = { Board_PIN_LED0 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX, PIN_TERMINATE }; /* * Application button pin configuration table: */ PIN_Config buttonPinTable[] = { Board_PIN_BUTTON0 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_POSEDGE, PIN_TERMINATE }; bool serviceFlag = true; bool watchdogExpired = false; Watchdog_Handle watchdogHandle; /* * ======== watchdogCallback ======== * Watchdog interrupt callback function. */ void watchdogCallback(uintptr_t unused) { /* Clear watchdog interrupt flag */ Watchdog_clear(watchdogHandle); watchdogExpired = true; Watchdog_setReload(watchdogHandle, 1500000); /* Insert timeout handling code here. */ } /* * ======== pinButtonFxn ======== * Callback function for the GPIO interrupt on Board_PIN_BUTTON0. */ void pinButtonFxn(PIN_Handle handle, PIN_Id pinId) { /* Clear serviceFlag to stop continuously servicing the watchdog */ serviceFlag = false; } /* * ======== main ======== */ void *mainThread(void *arg0) { char input; const char echoPrompt[] = "Echoing characters:\r\n"; UART_Handle uart; UART_Params uartParams; /* Call driver init functions */ // GPIO_init(); UART_init(); /* Create a UART with data processing off. */ UART_Params_init(&uartParams); uartParams.writeDataMode = UART_DATA_BINARY; uartParams.readDataMode = UART_DATA_BINARY; uartParams.readReturnMode = UART_RETURN_FULL; uartParams.readEcho = UART_ECHO_OFF; uartParams.baudRate = 115200; uart = UART_open(Board_UART0, &uartParams); if (uart == NULL) { /* UART_open() failed */ while (1); } // /* Turn on user LED */ // GPIO_write(Board_GPIO_LED0, Board_GPIO_LED_ON); UART_write(uart, echoPrompt, sizeof(echoPrompt)); // while (1) { // UART_read(uart, &input, 1); // UART_write(uart, &input, 1); // } Watchdog_Params params; /* Call board init functions */ Watchdog_init(); UART_write(uart, "0\n", 2); /* Open LED pin */ ledPinHandle = PIN_open(&ledPinState, ledPinTable); if(!ledPinHandle) { /* Error initializing board LED pin */ while (1); } UART_write(uart, "1\n", 2); /* Turn OFF user LED */ PIN_setOutputValue(ledPinHandle, Board_PIN_LED0, 0); /* Setup callback for button pin */ buttonPinHandle = PIN_open(&buttonPinState, buttonPinTable); if(!buttonPinHandle) { /* Error initializing button pins */ while (1); } if (PIN_registerIntCb(buttonPinHandle, &pinButtonFxn) != 0) { /* Error registering button callback function */ while (1); } PIN_setInterrupt(buttonPinHandle, Board_PIN_BUTTON0|PIN_IRQ_POSEDGE); /* Create and enable a Watchdog with resets disabled */ Watchdog_Params_init(¶ms); // params.callbackFxn = (Watchdog_Callback)watchdogCallback; params.resetMode = Watchdog_RESET_ON; watchdogHandle = Watchdog_open(Board_WATCHDOG0, ¶ms); if (watchdogHandle == NULL) { /* Error opening Watchdog */ while (1); } Watchdog_setReload(watchdogHandle, 1500000); UART_write(uart, "a\n", 2); /* Enter continous loop */ while (true) { /* Service watchdog if serviceFlag is true */ if (serviceFlag) { Watchdog_setReload(watchdogHandle, 1500000); //Watchdog_clear(watchdogHandle); } /* If watchdog expired since last started, turn ON LED */ if (watchdogExpired) { UART_write(uart, "b\n", 2); PIN_setOutputValue(ledPinHandle, Board_PIN_LED0, 1); sleep(5); Watchdog_clear(watchdogHandle); serviceFlag = true; watchdogExpired = false; PIN_setOutputValue(ledPinHandle, Board_PIN_LED0, 0); UART_write(uart, "c\n", 2); } } }
Alternatively, is there an other way to perform a reset? I tried SysCtrlSystemReset() and HapiResetDevice() but they just make the application stuck and don't do a reset.
