Tool/software: TI-RTOS
Is there any way to switch between BLE and sub 1 Ghz in cc1350 without losing BLE connection. The switching time from BLE to sub 1 Ghz and back to BLE is smaller than the connection interval.
Saandeep
Saandeep
Hello JXS,
Thanks! With the normal switching, the battery life seems to be only 4 hrs ( with cr2032 coin cell). I am (i) transmitting 1 sample every second at 868 Mhz (ii) measuring RSSI once every second at 2.4 GHz and (iii) switching between BLE to sub 1 GHz and back once every second. The highest current draw during these operations seems to be around 7 mA (as per the spec sheets) with which I should get a battery life of at least a day. This seems to be not normal as cc1350 specs mention 10 years of battery life. Should I expect to see this behavior or is there anything wrong?
Saandeep
