I am trying to use the battery monitor on the CC1350 chip.
1. Does the BAT register (Offset = 0028H) give the voltage value directly or do I need to process the register value in my code?
2. I am planning to use a supply of 4.5V and give 3.3V to the board through a voltage regulator. How can the battery monitor be used to keep the battery voltage in check in this case? How can I by-pass the voltage regulator without harming the board?
