hi,
a customer of mine is testing CC1310 in Long Range mode. Settings are as below:
We need to meet EN300220 and for that mode OCW ~ 21KHz. It means that Adjacent Channel Power Ratio is obligatory not Out Of Band Emissions. Unfortunately results for adjacent channel are not so good as required by EN300220 (Adj < -37dBc).
Could you advise please whether CC1310 is not suitable to using in narrow band application? What we can do to meet ACP requirements?
My first idea it to change deviation then 10kHz, then signal have wider bandwidth and ACP requirement is not valid because OCW >25KHz.
Can we change deviation to 10KHz and continue EN300220 compliance?
Has it impact to other RF parameter like sensitivity or blocking performance?
thanks a lot in advance
KR
Vincenzo
