Team,
following up this thread, can you clarify what's the minimum configurable capacitance value for CC1312R with the capacitor array?
Thanks!
Team,
Thanks!
TER, PM,
thanks for your answers, but now I am confused:
"When the minimal value is used for the cap array setting the cap array is turned off and what you have left is parasitics..."
Is that line #1 in the wiki table?
Are the 2.0 (pF?) only caused by parasitics?
The answer to my other post says: "...it's not possible to turn off the array, only to turn it to a minimum."
What's the capacitance value if the cap array delta is not applied? Such as:
Can you confirm that the data on the wiki page is also true for CC1312R?
(except that CC1312R only supports 48 MHz crystals.)
Thanks!
