i am using the cc1350 launchpad for my application. for the two board i have used easylinktx and easylinkrx example for the communication between two boards. for one board i have run the code tx and second for the
Rx . checking the data on terminal through uart. but communication distance is too less between this devices. not more than 10 ft . i dont know how it possible. should i have to do some setting in my code. for the longer distance?.
i am not using antenna i have checked it without antenna. so is there any impact on range if i will not using antenna.
please guide me.
