Other Parts Discussed in Thread: WI-SUN
I am wondering what the CONFIG_FH_NETNAME actually does. Is it like an extension to PAN ID?
In normal no-FH modes, there is a requirement that each PAN Co-ordinator has a unique PAN ID among those in vicinity to each other, according to the 15.4 spec. An active scan could determine other nearby PAN Co-ordinators with their respective PAN IDs and then select a unique PAN ID for itself. (The collector example does not seem to add this feature...?).
Anyway, when a sensor joins the collector, the sensor will receive and store the PAN ID of the collector (so the sensor does not need to know this PAN ID in advance). So will the same apply to the CONFIG_FH_NETNAME name? Or must this net name be written in stone at both the collector and sensors in advance?
Is the netname encrypted when transmitted over air? Or can everybody with a packet sniffer detect the name?
What is the purpose of the netname? And why is it only included in FH modes?
Thanks.
