We have an application that uses transceiver mode to periodically transmit some short packets. We also occasionally need to connect to a WLAN to run a short TCP connection. We have been using SL_NORMAL_POLICY for both scenarios, but now I'd like to see how much current SL_LOW_POWER_POLICY would save for the transceiver mode packets. It would be nice if we could set the power policy once to SL_LOW_POWER_POLICY and have it work for both transceiver mode and connected mode. If we did that, would there be a negative effect on connected mode?
