When I run any code with Energia on my board CC3200, or even if I simply verifiy, i have this type of answer. The sketch seems to work well, but I don't understand why I have this messages...
<command-line>:0:15: warning: ISO C99 requires whitespace after the macro name [enabled by default]
C:\Users\Valerio\AppData\Local\Energia15\packages\energia\hardware\cc3200\1.0.2\cores\cc3200\Stream.cpp: In member function 'bool Stream::find(char*)':
C:\Users\Valerio\AppData\Local\Energia15\packages\energia\hardware\cc3200\1.0.2\cores\cc3200\Stream.cpp:78:30: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
return findUntil(target, "");
Lo sketch usa 2.064 byte (0%) dello spazio disponibile per i programmi. Il massimo è 262.144 byte.
