Other Parts Discussed in Thread: UNIFLASH,
I successfully paired the launchpad in station mode using http server example. However, I am not able to find a way to do the same securely, i.e. use a key. There is a key field on the ios app. However I can't find where to set the key on the launchpad side. I browsed through the configuration settings in uniflash but didn't find anything. There has to be AES type of encryption capability, correct?
Thanks for your help and advice.
