I'd like to know if using sl_Select in multithreaded mode is supported/correct. I noticed that if SL_PLATFORM_MULTI_THREADED is defined then SimpleLinkSocketTriggerEventHandler is not defined. So I'm curious what is the proper usage (if any) of sl_Select in multi-threaded mode.
If sl_Select is not supported in multi-threaded mode, then is there an example for how to wait on incoming data when using a TCP socket using SimpleLink + FreeRTOS? I'd prefer to not to poll, but rather treat incoming data like bytes in a message queue, so I can have a thread wait on incoming bytes like I would using "xQueueReceive".
I'm using FreeRTOS as my OS.
Thanks!
