Part Number: SIMPLELINK-CC3220-SDK
Users have reported trouble installing the SimpleLink CC3220 SDK (v.1.30.01) on MacOS. Finder does not recognize the downloaded SDK as an application.
Until a fix is posted, as a workaround, please do the following*:
Install p7zip (I prefer using brew to install utilities)
In terminal type: 7za x ~/Downloads/simplelink_cc32xx_sdk1_30_01_03.app.7z
In terminal type: chmod +x ~/Downloads/simplelink_cc32xx_sdk1_30_01_03.app/Contents/MacOS/*
Now double click on the installer, and install via the gui interface
*Note: Your file path may change depending on where you downloaded the file. The file path above assumes that the SDK is in your Downloads folder. If you have changed the folder, please adjust the path above accordingly.
If you have any questions with the workaround, please let us know!
