Please send me info so I can order additional parts! Also, is there a place where I can find an answer to the error I am getting above? Can you suggest a better example than this one? Also, should I go with the cloud CCS or stick with the downloaded version? I have a Samsung PC laptop and a MacBook, any thoughts? Thank you for your time and help!
Your friend Edward
Hi Josh,
I am waiting for your info, but I am not clear where to reply thank you and if I need to send you my info!
Thank you,
Edward
Hi Edward,
You will want to connect to the COM port named "XDS110 Class Application/User UART". Please also make sure you are setting the baud rate of your serial connection to 115200.
Please make sure your LaunchPad is put into development mode so the debugger can use the JTAG. Refer to section 4.2 of this guide for details -
http://www.ti.com/lit/ug/swru461/swru461.pdf
We are in the process of refining our Wi-Fi and BLE software reference using the SimpleLink devices and making sure it is robust/easy to use. If you wait for the official release, you will have a better experience during development.
Until then, I recommend starting work with the SAIL plug-in as Josh mentioned and integrating that with the MQTT example to demonstrate publishing sensor data to the cloud.
Ben M
