CCS/CC3220SF-LAUNCHXL: AWS IOT subscribe_publish_sample certificates
Part Number: CC3220SF-LAUNCHXL
Other Parts Discussed in Thread: CC3220SF,
I have created an account on AWS IOT
I have created the needed certificates, policy and a "thing" and did all the recommended settings.
I also had imported the aws iot sdk for cc3220sf sample "subscribe_publish_sample" for freertos-css.
From AWS I have 4 certificates : ( created , policy attached and activated )
......xxx-certificate.pem
......xxx-private.pem.key
......xxx-public.pem.key
VeriSign-Class 3-Public....-G5.pem
and the aws  accesskeys.
What are the next steps to integrate these certificates in to the mentioned project for the CC3220SF-LAUNCHXL board ?
Any help is appreciated.
  • Hi Rick,
    You can reference the quick start guide for the next steps.  If you become stuck, there is a helpful E2E post below as well.
  • Hi Austin,
    Thanks for your help.
    Unfortunately the link posted apply when certificates from "C:\ti\simplelink_cc32xx_sdk_1_40_01_00\tools\cc32xx_tools\certificate-playground" are used.
    In my case I used certificates created by amazon.
    After followed the Ti Resource Explorer "SimpleLink CC32XX SDK AWS IoT Plugin guide"
    I got this output from serial port :
    CC3220 has connected to AP and acquired an IP address.
    IP Address: 192.168.1.8
    Current time: Mon Jan  1 17:42:16 1900
    Flashing certificate file ...
    successfully wrote file /cert/ca.der to flash
    successfully wrote file /cert/cert.der to flash
    successfully wrote file /cert/key.der to flash
    AWS IoT SDK Version 2.1.1-
    Connecting...
    ERROR: runAWSClient L#108
    Error(-24) connecting to abcd1234...xyzi.iot.us-east-1.amazonaws.com:8883
    Subscribing...
    ERROR: runAWSClient L#126
    Error subscribing (-13)
    ERROR: runAWSClient L#178
    An error occurred in the loop. Error code = -13
    The current time states 1900 and Jan 1.
    I have no clue why. I think this is the reason why the TLS handshaking fails.
    Any help would be appreciated.
  • I forgot to mention that on the AWS side my policy is:
    "Version": "2012-10-17",
    "Statement": [
    "Effect": "Allow",
    "Action": "iot:*",
    "Resource": "*"
  • Anyone having this kind of issue with the CC3220SF-LAUNCHXL and the aws subscribe-publish sample from the amazon sdk?
  • Hi Rick,
    Please find the suggestion for this issue on your duplicate thread below:
