Other Parts Discussed in Thread: CC3100, CC31XXEMUBOOST
Hi all,
when using Radio Tool with CC31XXEMUBOOST error message -101 occurs, see picture below.
Exact process how to reproduce error, after connection:
- Either if data Rate is changed in continous or packetized RX mode (After setting the Data Rate in the TX setup, finish signal emission after signal emission, modify it to another Data rate, and then start signal emission again(TX Test Started) - error occurs aperiodically
- Or in Continuous TX, when launching a signal after setting a specific OFDM data rate
- Error occurs only in TX not in RX mode
Changing to another computer, following error message occurs:
Following Hardware/Software is used:
- CC3100/CC3200 Radio Tool v1.2.5942.19689
- CC31XXEMUBOOST Board Rev.3
