Other Parts Discussed in Thread: CC3200
Hi All CC3200 AEs,
I attached my test file in the post. For general idle_profile, the current is around 1.5mA. However, when i enable sl_stop and comment out wlanconnect(). the current consumption is 9.9mA. This is really weird thing. If I disable NWP, current consumption should be lower than enable NWP. Is there any power policy is related with NWP ? If i disable NWP, can CC3200 enter LPDS mode? thanks.
//***************************************************************************** // // Copyright (C) 2014 Texas Instruments Incorporated - http://www.ti.com/ // // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. // //***************************************************************************** //***************************************************************************** // // Application Name - Idle Profile // Application Overview - Idle profile enables the user to measure current // values, power consumption and other such parameters // for CC3200, when the device is essentially idle(both // NWP and APPS subsystems in low power deep sleep // condition). The other main objective behind this // application is to introduce the user to the easily // configurable power management framework. // Application Details - // http://processors.wiki.ti.com/index.php/CC32xx_Idle_Profile_Application // or // docs\examples\CC32xx_Idle_Profile_Application.pdf // //***************************************************************************** //**************************************************************************** // //! \addtogroup idle_profile //! @{ // //**************************************************************************** // Standard includes #include <string.h> //driverlib includes #include "hw_ints.h" #include "hw_types.h" #include "hw_memmap.h" #include "interrupt.h" #include "prcm.h" #include "wdt.h" #include "utils.h" #include "rom.h" #include "rom_map.h" // Simplelink includes #include "simplelink.h" //middleware includes #include "cc_types.h" #include "rtc_hal.h" #include "gpio_hal.h" #include "uart_drv.h" #include "cc_timer.h" #include "cc_pm_ops.h" // OS(Free-RTOS/TI-RTOS) includes #include "osi.h" // Common interface includes #include "wdt_if.h" #include "pinmux.h" #define APPLICATION_VERSION "1.1.1" // // Values for below macros shall be modified as per access-point(AP) properties // SimpleLink device will connect to following AP when application is executed // //#define SSID_NAME "cc3200demo" /* AP SSID */ //#define SECURITY_TYPE SL_SEC_TYPE_OPEN /* Security type (OPEN or WEP or WPA) */ //#define SECURITY_KEY "" /* Password of the secured AP */ //#define SPAWN_TASK_PRIORITY 9 //#define GPIO_13 13 //#define GPIO_SRC_WKUP GPIO_13 //#define APP_UDP_PORT 5001 //#define LPDS_DUR_SEC 60 //#define LPDS_DUR_NSEC 0 //#define FOREVER 1 //#define BUFF_SIZE 1472 //#define SL_STOP_TIMEOUT 30 //#define OSI_STACK_SIZE 1024 //#define CONNECTION_RETRIES 5 //#define UART_PRINT(x) uart_write(g_tUartHndl, x, strlen(x)) #define SSID_NAME "Lisa ding"//"cc3200demo" /* AP SSID */ #define SECURITY_TYPE SL_SEC_TYPE_WPA //SL_SEC_TYPE_OPEN /* Security type (OPEN or WEP or WPA) */ #define SECURITY_KEY "happyday"//"" /* Password of the secured AP */ #define SPAWN_TASK_PRIORITY 9 #define GPIO_13 13 #define GPIO_SRC_WKUP GPIO_13 #define APP_UDP_PORT 5001 #define LPDS_DUR_SEC 10//60 #define LPDS_DUR_NSEC 0 #define FOREVER 1 #define BUFF_SIZE 1472 #define SL_STOP_TIMEOUT 30 #define OSI_STACK_SIZE 1024 #define CONNECTION_RETRIES 5 #define UART_PRINT(x) uart_write(g_tUartHndl, x, strlen(x)) #define WD_PERIOD_MS 10000 #define MAP_SysCtlClockGet 80000000 #define MILLISECONDS_TO_TICKS(ms) ((MAP_SysCtlClockGet/1000) * (ms)) enum ap_events{ EVENT_CONNECTION = 0x1, EVENT_DISCONNECTION = 0x2, EVENT_IP_ACQUIRED = 0x4, WDOG_EXPIRED = 0x8, CONNECTION_FAILED = 0x10 }; //**************************************************************************** // LOCAL FUNCTION PROTOTYPES //**************************************************************************** void sl_WlanEvtHdlr(SlWlanEvent_t *pSlWlanEvent); void sl_NetAppEvtHdlr(SlNetAppEvent_t *pNetAppEvent); static void DisplayBanner(); void PrintIPAddr(unsigned int uiIpaddr); void WatchdogIntHandler(void); int WlanConnect(); void WlanDisconnect(); int gpio_intr_hndlr(int gpio_num); void TimerCallback(void *vParam); cc_hndl SetTimerAsWkUp(); cc_hndl SetGPIOAsWkUp(); static void BoardInit(); void UDPServerTask(void *pvParameters); void TimerGPIOTask(void *pvParameters); void SwitchToStaMode(int iMode); //***************************************************************************** // GLOBAL VARIABLES -- Start //***************************************************************************** #ifndef USE_TIRTOS #if defined(ccs) || defined(gcc) extern void (* const g_pfnVectors[])(void); #endif #if defined(ewarm) extern uVectorEntry __vector_table; #endif #endif #ifdef DEBUG_GPIO #define GPIO_09 9 cc_hndl tGPIODbgHndl; #endif OsiMsgQ_t g_tConnectionFlag; OsiMsgQ_t g_tWkupSignalQueue; cc_hndl g_tUartHndl; unsigned long g_ulIpAddr = 0; unsigned char g_ucFeedWatchdog = 0; unsigned char g_ucWdogCount = 0; OsiMsgQ_t g_tConnection = 0; signed char g_cBuffer[BUFF_SIZE]; char g_cErrBuff[100]; //***************************************************************************** // GLOBAL VARIABLES -- End //***************************************************************************** //***************************************************************************** // Local Function Prototypes //***************************************************************************** extern void lp3p0_setup_power_policy(int power_policy); extern int platform_init(); // Loop forever, user can change it as per application's requirement #define LOOP_FOREVER() \ {\ while(1); \ } // check the error code and handle it #define ASSERT_ON_ERROR(error_code)\ {\ if(error_code < 0) \ {\ sprintf(g_cErrBuff,"Error [%d] at line [%d] in "\ "function [%s]", error_code,__LINE__,\ __FUNCTION__);\ UART_PRINT(g_cErrBuff);\ UART_PRINT("\n\r");\ return error_code;\ }\ } //***************************************************************************** // //! DisplayBanner //! //! \param none //! //! \return none //! //***************************************************************************** static void DisplayBanner() { UART_PRINT("\n\n\n\r"); UART_PRINT("\t\t *********************************************\n\r"); UART_PRINT("\t\t CC3200 Idle Profile Application \n\r"); UART_PRINT("\t\t *********************************************\n\r"); UART_PRINT("\n\n\n\r"); } //***************************************************************************** // //! Application defined hook (or callback) function - the tick hook. //! The tick interrupt can optionally call this //! //! \param none //! //! \return none //! //***************************************************************************** void vApplicationTickHook( void ) { } //***************************************************************************** // //! Application defined hook (or callback) function - assert //! //! \param none //! //! \return none //! //***************************************************************************** void vAssertCalled( const char *pcFile, unsigned long ulLine ) { while(1) { } } //***************************************************************************** // //! Application defined idle task hook //! //! \param none //! //! \return none //! //***************************************************************************** void vApplicationIdleHook( void ) { cc_idle_task_pm(); } //***************************************************************************** // //! Application defined malloc fail hook //! //! \param none //! //! \return none //! //***************************************************************************** void vApplicationMallocFailedHook() { while(1) { } } //***************************************************************************** // //! Application defined stack overflow hook //! //! \param none //! //! \return none //! //***************************************************************************** void vApplicationStackOverflowHook() { while(1) { } } //***************************************************************************** // //! Print the IP address in the dotted decimal form //! //! \param uiIpaddr is the IP address of the device in integer form //! //! \return none //! //***************************************************************************** void PrintIPAddr(unsigned int uiIpaddr) { char pcIpString[16]; unsigned char ucLen1, ucLen2, ucLen3, ucLen4; ucLen1 = sprintf(pcIpString, "%u", (uiIpaddr & 0xFF000000)>>24); ucLen2 = sprintf((pcIpString + ucLen1), ".%u", (uiIpaddr & 0x00FF0000)>>16); ucLen3 = sprintf((pcIpString + ucLen1 + ucLen2), ".%u", (uiIpaddr & 0x0000FF00)>>8); ucLen4 = sprintf((pcIpString + ucLen1 + ucLen2 + ucLen3), ".%u\0", (uiIpaddr & 0x000000FF)); UNUSED(ucLen4); UART_PRINT(pcIpString); } //**************************************************************************** // //! \brief This function handles WLAN events //! //! \param[in] pSlWlanEvent is the event passed to the handler //! //! \return None // //**************************************************************************** void sl_WlanEvtHdlr(SlWlanEvent_t *pSlWlanEvent) { unsigned char ucQueueMsg = 0; switch(pSlWlanEvent->Event) { case SL_WLAN_CONNECT_EVENT: ucQueueMsg = (unsigned char)EVENT_CONNECTION; if(g_tConnection != 0) { osi_MsgQWrite(&g_tConnection, &ucQueueMsg, OSI_WAIT_FOREVER); } else { UART_PRINT("Error: sl_WlanEvtHdlr: Queue does not exist\n\r"); while(FOREVER); } UART_PRINT("C\n\r"); break; case SL_WLAN_DISCONNECT_EVENT: ucQueueMsg = (unsigned char)EVENT_DISCONNECTION; if(g_tConnection != 0) { osi_MsgQWrite(&g_tConnection, &ucQueueMsg, OSI_WAIT_FOREVER); } else { UART_PRINT("Error: sl_WlanEvtHdlr: Queue does not exist\n\r"); while(FOREVER); } UART_PRINT("D\n\r"); break; default: break; } } //**************************************************************************** // //! \brief This function handles events for IP address acquisition via DHCP //! indication //! //! \param[in] pNetAppEvent is the event passed to the handler //! //! \return None // //**************************************************************************** void sl_NetAppEvtHdlr(SlNetAppEvent_t *pNetAppEvent) { unsigned char ucQueueMsg = 0; switch(pNetAppEvent->Event) { case SL_NETAPP_IPV4_IPACQUIRED_EVENT: case SL_NETAPP_IPV6_IPACQUIRED_EVENT: g_ulIpAddr = pNetAppEvent->EventData.ipAcquiredV4.ip; ucQueueMsg = (unsigned char)EVENT_IP_ACQUIRED; if(g_tConnection != 0) { osi_MsgQWrite(&g_tConnection, &ucQueueMsg, OSI_WAIT_FOREVER); } else { UART_PRINT("Error: sl_NetAppEvtHdlr: Queue does not exist\n\r"); while(FOREVER); } UART_PRINT("IP: "); PrintIPAddr(g_ulIpAddr); UART_PRINT("\n\r"); break; default: break; } } //***************************************************************************** // //! This function gets triggered when HTTP Server receives Application //! defined GET and POST HTTP Tokens. //! //! \param pSlHttpServerEvent Pointer indicating http server event //! \param pSlHttpServerResponse Pointer indicating http server response //! //! \return None //! //***************************************************************************** void sl_HttpServerCallback(SlHttpServerEvent_t *pSlHttpServerEvent, SlHttpServerResponse_t *pSlHttpServerResponse) { } //***************************************************************************** // //! \brief This function handles General Events //! //! \param[in] pDevEvent - Pointer to General Event Info //! //! \return None //! //***************************************************************************** void SimpleLinkGeneralEventHandler(SlDeviceEvent_t *pDevEvent) { } //***************************************************************************** // //! This function handles socket events indication //! //! \param[in] pSock - Pointer to Socket Event Info //! //! \return None //! //***************************************************************************** void SimpleLinkSockEventHandler(SlSockEvent_t *pSock) { // // This application doesn't work w/ socket - Events are not expected // } //***************************************************************************** // //! The interrupt handler for the watchdog timer //! //! \param None //! //! \return None // //***************************************************************************** void WatchdogIntHandler(void) { // // If we have been told to stop feeding the watchdog, return immediately // without clearing the interrupt. This will cause the system to reset // next time the watchdog interrupt fires. // if(!g_ucFeedWatchdog) { return; } unsigned char ucQueueMsg = 0; if(g_ucWdogCount < CONNECTION_RETRIES) { g_ucWdogCount++; ucQueueMsg = (unsigned char)WDOG_EXPIRED; MAP_WatchdogIntClear(WDT_BASE); } else { g_ucFeedWatchdog = 0; ucQueueMsg = (unsigned char)CONNECTION_FAILED; MAP_WatchdogIntClear(WDT_BASE); } if(g_tConnection != 0) { osi_MsgQWrite(&g_tConnection, &ucQueueMsg, OSI_NO_WAIT); } else { UART_PRINT("Error: WatchdogIntHandler: Queue does not exist\n\r"); } } //***************************************************************************** // //! \brief Connecting to a WLAN Accesspoint //! This function connects to the required AP (SSID_NAME). //! This code example assumes the AP doesn't use WIFI security. //! The function will return only once we are connected //! and have acquired IP address //! //! \param[in] None //! //! \return 0 means success, -1 means failure //! //! \note //! //! \warning If the WLAN connection fails or we don't aquire an IP address, //! We will be stuck in this function forever. // //***************************************************************************** int WlanConnect() { int iRetCode = 0; int iRetVal = 0; int iConnect = 0; unsigned char ucQueueMsg = 0; SlSecParams_t secParams; secParams.Key = (signed char *)SECURITY_KEY; secParams.KeyLen = strlen((const char *)secParams.Key); secParams.Type = SECURITY_TYPE; // // Set up the watchdog interrupt handler. // WDT_IF_Init(WatchdogIntHandler, MILLISECONDS_TO_TICKS(WD_PERIOD_MS)); /* Enabling the Sleep clock for the Watch Dog Timer*/ MAP_PRCMPeripheralClkEnable(PRCM_WDT, PRCM_SLP_MODE_CLK); g_ucFeedWatchdog = 1; g_ucWdogCount = 0; while(!(ucQueueMsg & (EVENT_IP_ACQUIRED|CONNECTION_FAILED))) { UART_PRINT("Trying to connect to AP: "); UART_PRINT(SSID_NAME); UART_PRINT("\n\r"); sl_WlanConnect((signed char *)SSID_NAME, strlen((const char *)SSID_NAME), 0, &secParams, 0); iConnect = 0; do{ osi_MsgQRead(&g_tConnection, &ucQueueMsg, OSI_WAIT_FOREVER); switch(ucQueueMsg) { case EVENT_CONNECTION: iConnect = 1; break; case EVENT_IP_ACQUIRED: iRetVal = 0; break; case WDOG_EXPIRED: // // disconnect from the Access Point // if(iConnect) { WlanDisconnect(); } // // stop the simplelink with reqd. timeout value (30 ms) // sl_Stop(SL_STOP_TIMEOUT); UART_PRINT("sl stop\n\r"); MAP_UtilsDelay(8000); // // starting the simplelink // sl_Start(NULL, NULL, NULL); UART_PRINT("sl start\n\r"); break; case EVENT_DISCONNECTION: iConnect = 0; break; case CONNECTION_FAILED: iRetVal = -1; break; default: UART_PRINT("unexpected event\n\r"); break; } }while(ucQueueMsg == (unsigned char)EVENT_CONNECTION); } iRetCode = MAP_WatchdogRunning(WDT_BASE); if(iRetCode) { WDT_IF_DeInit(); MAP_PRCMPeripheralClkDisable(PRCM_WDT, PRCM_RUN_MODE_CLK); } ASSERT_ON_ERROR(iRetVal); return(iRetVal); } //***************************************************************************** // //! \brief disconnection from the WLAN Accesspoint //! //! \param[in] None //! //! \return None //! //! \note //! //! \warning If the WLAN disconnection fails, We will be stuck in this //! function forever. // //***************************************************************************** void WlanDisconnect() { unsigned char ucQueueMsg = 0; while(ucQueueMsg != (unsigned char)EVENT_DISCONNECTION) { sl_WlanDisconnect(); osi_MsgQRead(&g_tConnection, &ucQueueMsg, OSI_WAIT_FOREVER); } return; } //***************************************************************************** // //! Board Initialization & Configuration //! //! \param None //! //! \return None // //***************************************************************************** static void BoardInit(void) { /* In case of TI-RTOS vector table is initialize by OS itself */ #ifndef USE_TIRTOS // // Set vector table base // #if defined(ccs) || defined(gcc) IntVTableBaseSet((unsigned long)&g_pfnVectors[0]); #endif #if defined(ewarm) IntVTableBaseSet((unsigned long)&__vector_table); #endif #endif // // Enable Processor // MAP_IntMasterEnable(); MAP_IntEnable(FAULT_SYSTICK); PRCMCC3200MCUInit(); } //***************************************************************************** // //! \brief callback function for gpio interrupt handler //! //! \param gpio_num is the gpio number which has triggered the interrupt //! //! \return 0 // //***************************************************************************** int gpio_intr_hndlr(int gpio_num) { unsigned char queue_msg = 2; if(GPIO_SRC_WKUP == gpio_num) { osi_MsgQWrite(&g_tWkupSignalQueue, &queue_msg, OSI_NO_WAIT); } return 0; } //***************************************************************************** // //! \brief callback function for timer interrupt handler //! //! \param vParam is a general void pointer (not used here) //! //! \return None // //***************************************************************************** void TimerCallback(void *vParam) { unsigned char ucQueueMsg = 1; osi_MsgQWrite(&g_tWkupSignalQueue, &ucQueueMsg, OSI_NO_WAIT); return; } //***************************************************************************** // //! \brief set GPIO as a wake up source from low power modes. //! //! \param none //! //! \return handle for the gpio used // //***************************************************************************** cc_hndl SetGPIOAsWkUp() { cc_hndl tGPIOHndl; // // setting up GPIO as a wk up source and configuring other related // parameters // tGPIOHndl = cc_gpio_open(GPIO_SRC_WKUP, GPIO_DIR_INPUT); cc_gpio_enable_notification(tGPIOHndl, GPIO_SRC_WKUP, INT_FALLING_EDGE, (GPIO_TYPE_NORMAL | GPIO_TYPE_WAKE_SOURCE)); return(tGPIOHndl); } //***************************************************************************** // //! \brief set Timer as a wake up source from low power modes. //! //! \param none //! //! \return handle for the Timer setup as a wakeup source // //***************************************************************************** cc_hndl SetTimerAsWkUp() { cc_hndl tTimerHndl; struct cc_timer_cfg sRealTimeTimer; struct u64_time sInitTime, sIntervalTimer; // // setting up Timer as a wk up source and other timer configurations // sInitTime.secs = 0; sInitTime.nsec = 0; cc_rtc_set(&sInitTime); sRealTimeTimer.source = HW_REALTIME_CLK; sRealTimeTimer.timeout_cb = TimerCallback; sRealTimeTimer.cb_param = NULL; tTimerHndl = cc_timer_create(&sRealTimeTimer); sIntervalTimer.secs = LPDS_DUR_SEC; sIntervalTimer.nsec = LPDS_DUR_NSEC; cc_timer_start(tTimerHndl, &sIntervalTimer, OPT_TIMER_PERIODIC); return(tTimerHndl); } //***************************************************************************** // //! Check the device mode and switch to STATION(STA) mode //! restart the NWP to activate STATION mode //! //! \param iMode (device mode) //! //! \return None // //***************************************************************************** void SwitchToStaMode(int iMode) { if(iMode != ROLE_STA) { sl_WlanSetMode(ROLE_STA); MAP_UtilsDelay(80000); sl_Stop(10); MAP_UtilsDelay(80000); sl_Start(0,0,0); } } //***************************************************************************** // //! \brief Task Created by main fucntion.This task starts simpleink, set NWP //! power policy, connects to an AP. Give Signal to the other task about //! the connection.wait for the message form the interrupt handlers and //! the other task. Accordingly print the wake up cause from the low //! power modes. //! //! \param pvParameters is a general void pointer (not used here). //! //! \return none // //***************************************************************************** void TimerGPIOTask(void *pvParameters) { cc_hndl tTimerHndl = NULL; cc_hndl tGPIOHndl = NULL; unsigned char ucQueueMsg = 0; unsigned char ucSyncMsg = 0; int iRetVal = 0; // // Displays the Application Banner // DisplayBanner(); // // creating the queue for signalling about connection events // iRetVal = osi_MsgQCreate(&g_tConnection, NULL, sizeof( unsigned char ), 3); if (iRetVal < 0) { UART_PRINT("unable to create the msg queue\n\r"); LOOP_FOREVER(); } // // starting the simplelink // iRetVal = sl_Start(NULL, NULL, NULL); if (iRetVal < 0) { UART_PRINT("Failed to start the device \n\r"); LOOP_FOREVER(); } // // Swtich to STA mode if device is not // SwitchToStaMode(iRetVal); // // Set the power management policy of NWP // iRetVal = sl_WlanPolicySet(SL_POLICY_PM, SL_NORMAL_POLICY, NULL, 0); if (iRetVal < 0) { UART_PRINT("unable to configure network power policy\n\r"); LOOP_FOREVER(); } #if 0 sl_Stop(SL_STOP_TIMEOUT); UART_PRINT("SL_STOP2\n\r"); #endif #if 1 // // connecting to the Access Point // if(-1 == WlanConnect()) { sl_Stop(SL_STOP_TIMEOUT); UART_PRINT("Connection to AP failed\n\r"); } else { UART_PRINT("Connected to AP\n\r"); // //signal the other task about the sl start and connection to the AP // iRetVal = osi_MsgQWrite(&g_tConnectionFlag, &ucSyncMsg, OSI_WAIT_FOREVER); if (iRetVal < 0) { UART_PRINT("unable to create the msg queue\n\r"); LOOP_FOREVER(); } } #endif // // Queue management related configurations // iRetVal = osi_MsgQCreate(&g_tWkupSignalQueue, NULL, sizeof( unsigned char ), 10); if (iRetVal < 0) { UART_PRINT("unable to create the msg queue\n\r"); LOOP_FOREVER(); } // // setting Timer as one of the wakeup source // tTimerHndl = SetTimerAsWkUp(); // // setting some GPIO as one of the wakeup source // tGPIOHndl = SetGPIOAsWkUp(); /* handles, if required, can be used to stop the timer, but not used here*/ UNUSED(tTimerHndl); UNUSED(tGPIOHndl); // // setting Apps power policy // lp3p0_setup_power_policy(POWER_POLICY_STANDBY); while(FOREVER) { // // waits for the message from the various interrupt handlers(GPIO, // Timer) and the UDPServerTask. // osi_MsgQRead(&g_tWkupSignalQueue, &ucQueueMsg, OSI_WAIT_FOREVER); switch(ucQueueMsg){ case 1: UART_PRINT("timer\n\r"); break; case 2: UART_PRINT("GPIO\n\r"); break; case 3: UART_PRINT("host irq\n\r"); break; default: UART_PRINT("invalid msg\n\r"); break; } } } //***************************************************************************** // //! \brief Task Created by main fucntion. This task creates a udp server and //! wait for packets. Upon receiving the packet, signals the other task. //! //! \param pvParameters is a general void pointer (not used here). //! //! \return none // //***************************************************************************** void UDPServerTask(void *pvParameters) { unsigned char ucSyncMsg; unsigned char ucQueueMsg = 3; int iSockDesc = 0; int iRetVal = 0; sockaddr_in sLocalAddr; sockaddr_in sClientAddr; unsigned int iAddrSize = 0; // // waiting for the other task to start simplelink and connection to the AP // osi_MsgQRead(&g_tConnectionFlag, &ucSyncMsg, OSI_WAIT_FOREVER); osi_MsgQDelete(&g_tConnectionFlag); // // configure the Server // sLocalAddr.sin_family = SL_AF_INET; sLocalAddr.sin_port = sl_Htons((unsigned short)APP_UDP_PORT); sLocalAddr.sin_addr.s_addr = 0; iAddrSize = sizeof(sockaddr_in); // // creating a UDP socket // iSockDesc = sl_Socket(SL_AF_INET,SL_SOCK_DGRAM, 0); if(iSockDesc < 0) { UART_PRINT("sock error\n\r"); LOOP_FOREVER(); } // // binding the socket // iRetVal = sl_Bind(iSockDesc, (SlSockAddr_t *)&sLocalAddr, iAddrSize); if(iRetVal < 0) { UART_PRINT("bind error\n\r"); LOOP_FOREVER(); } while(FOREVER) { // // waiting on a UDP packet // iRetVal = sl_RecvFrom(iSockDesc, g_cBuffer, BUFF_SIZE, 0, ( SlSockAddr_t *)&sClientAddr, (SlSocklen_t*)&iAddrSize ); if(iRetVal > 0) { // // signal the other task about receiving the UDP packet // osi_MsgQWrite(&g_tWkupSignalQueue, &ucQueueMsg, OSI_WAIT_FOREVER); } else { UART_PRINT("recv error\n\r"); LOOP_FOREVER(); } } } //**************************************************************************** // MAIN FUNCTION //**************************************************************************** void main(void) { int iRetVal; // // Board Initialization // BoardInit(); // // Configure the pinmux settings for the peripherals exercised // PinMuxConfig(); // // Initialize the platform // platform_init(); // // Configuring UART // g_tUartHndl = uart_open(PRCM_UARTA0); #ifdef DEBUG_GPIO // // setting up GPIO for indicating the entry into LPDS // tGPIODbgHndl = cc_gpio_open(GPIO_09, GPIO_DIR_OUTPUT); cc_gpio_write(tGPIODbgHndl, GPIO_09, 1); #endif // // Start the SimpleLink Host // iRetVal = VStartSimpleLinkSpawnTask(SPAWN_TASK_PRIORITY); if(iRetVal < 0) { UART_PRINT("could not create simplelink task\n\r"); LOOP_FOREVER(); } // // sync object for inter thread communication // iRetVal = osi_MsgQCreate(&g_tConnectionFlag, NULL, sizeof( unsigned char ), 1); if(iRetVal < 0) { UART_PRINT("could not create msg queue\n\r"); LOOP_FOREVER(); } // // Task creation for providing host_irq as a wake up source(LPDS) // iRetVal = osi_TaskCreate(UDPServerTask, (const signed char *)"UDP Server waiting to recv"\ "packets", OSI_STACK_SIZE, NULL, 1, NULL ); if(iRetVal < 0) { UART_PRINT("First Task creation failed\n\r"); LOOP_FOREVER(); } // // setting up timer and gpio as source for wake up from lPDS // iRetVal = osi_TaskCreate(TimerGPIOTask, (const signed char*)"Configuring Timer and GPIO as"\ " wake src", OSI_STACK_SIZE, NULL, 1, NULL ); if(iRetVal < 0) { UART_PRINT("Second Task creation failed\n\r"); LOOP_FOREVER(); } // // Start the task scheduler // osi_start(); }
