Other Parts Discussed in Thread: CC3220SF, UNIFLASH
While using local ota in cc3220sf the following issue is found while parsing the ota.cmd file
Error: -16384, Couldn't parse the received Json file <CR><LF>
[OtaArchive_RunParseTar] ERROR in _BundleCmdFile_Parse, Status=-16384<CR><LF>
The sdk used is simplelink_cc32xx_sdk_1_60_00_04
The ota.cmd file created by uniflash 4.2.1 is
"digest":"ca07d9c0c8cf718e227cc62a5198025728005c056ab53b5c8242af364fa437ed",
"certificate":"",
"signature_base64":"",
"secured":1,
"bundle":1,
"filename":"/sys/mcubootinfo.bin"
"digest":"9c3c60e4668c8775a88c123d6a931e7cc2b0a1d5ffcb9b23cd8c0b957b5b7d52",
"certificate":"dummy-root-ca-cert",
"signature_base64":"QnynCxGm3jiv4HKns6NyMIu/dFq3hOcEqC/USqAyeSlDYYWHsp1x3b8J4wqbcE00zrglnf+0FhQeRxvIkis2GuOlced+vkYF8XXmx58U/NqyJsolSfsW/Nm7rfzwL0KU2cFyb3y6Ah2LQeaPt5L2NORyad+oa4W9/IjtmM4zant/bVUNo1aZtCqQV8PE3ZTZfvn16wLFrqDuWUQ7T5WLLRsbEdamsnl1yT+JuXRL+JpQItsMrNxIGcn1yK0GuShAqMGSWonPPg3ZQpw/h7ibQ+2L0cA/NhnM0p0sk1pUAa4bX3UPnjsURNITr2WI7j0e9YDeKI+afXzGuT5hlqYyuw==",
"secured":1,
"bundle":1,
"filename":"/sys/mcuflashimg.bin"
"digest":"feef1c942ef14001711ca61a59f495c6ac88f2c495f2513ceb63c5b7c33e7b22",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/callout.png"
"digest":"7698ab55269ac5ddc047cd17896ed70b732f039997c4950a8b3a6c8aaef65774",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/d.js"
"digest":"835c4095ba83871be0da1399233fda6fa0666f8f77d131f600c27d51b4cea74b",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/favicon.ico"
"digest":"263d362b7f6f6ded3c7d4f9839790ff55f162d888e0ebc8af578e375a057df06",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/index.htm"
"digest":"fef40a1e33420f00bdd431b98bc2c78f858a70792695df4dece3b9f5b3898281",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/item.png"
"digest":"64a3e7cc0ebdc06a1835b046d8d56f895404b7b780eac116ec765fb4a1871cd2",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/listdir.cgi"
"digest":"e8881d2e9ebf02222ae583327dbf089aaaf955e55d61ce1bdd09244bc6c461b9",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/login.htm"
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/main.html"
"digest":"49705c4fa4474f410f08dcc1b1ae6a49a3ead3261885edb492ddefedebbd99d9",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/monthbackward_normal.gif"
"digest":"5d97d14f870879185cc4c1da2d387f3c26b0a03eaec4100ea17580c732267d8a",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/monthforward_normal.gif"
"digest":"637ce1bf5478487417624334241d7fec1c36f627ea0af4fd1557e5a4e7c865c3",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/req.htm"
"digest":"370b51bfc70da3aa69bd8415822ec4259241a5dbf9793085e34000108eb7a556",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/site_test.css"
"certificate":"",
"secured":0,
"bundle":1,
"filename":"/www/upgrade.htm"
"digest":"34941765501d16a4ab776c3a74d89945f1a2575c5893069f62ffbe803f344549",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"dummy-root-ca-cert"
"digest":"a160b855d7a00a6002922181377249a80ecd6a738d23e1dd8976c8bb7fad1bcb",
"certificate":"",
"secured":0,
"bundle":1,
"filename":"dummy_ota_vendor_cert.der"
"digest":"d4ed4c744b1d68a60bee9670f5d95b7dc705ee93b9cec1656a17a9519623baba",
"certificate":"",
"signature_base64":"oATmfueKeInbDmOVA/smKyBe1swJ5yWzgo4KLkVuBY84su6+/pWsfAHbiUMnQl8jGLQ0li067A4bIl1UC1yMsRE9VJhB3xy/547ZyPpB/MTvaNT4v33kuTPUdXO7dbo4QYQHyeXX+vNuLoIrx419ePkWiw3RRR15Z2zPYy+tWFYL7J2jQQ0ttOgjeMCoSgYriMyV4C2kWqrhungSKTV/u+o65hz1+DllBF2SFgqltmyfWjDXkIjsvuPfHE7+I2Ns7fJcyNBiiS2fT3CUsw3Ky5aWPLZkz3orilandeOvmAfsB9f5Wcdelic4KTvKZVIkLIb46y5rPnJy6BCNQe1snA==",
"secured":1,
"bundle":1,
"filename":"/sys/servicepack.ucf"
