Other Parts Discussed in Thread: WL1837
Hi, we found a persistent peak level in our module(use TI WL1837Q) at the 4 times of WLAN 2.4G when we tested the receiver spurious emissions (eg.when we tested the receiver spurious emissions of 2437MHz,and there is a max level about -71dBm appear,the base noise is about -80dBm ) . the same issue also appears in TI industrial IC(TI WL1837,TI EVM 1877Q), SO we and our customers expect that it should be solved by the source(TI ) .Detail information pelease see the attachment
