Other Parts Discussed in Thread: WL1835MODCOM8B, WL18XXCOM82SDMMC
I am trying to get the Wilink module WL1835MODCOM8B working with the MYIR RicoBoard
The WL1835MODCOM8B board is connected via the WL18XXCOM82SDMMC board and a Flatfoil to the RicoBoard
I have adapted the dts file and the config file and build the kernel according the WL18xx WiFi Build Process
I used the tisdk-rootfs-image-am437x-evm file system and added the system files from the ws-build/fs folder to it
after the kernel boot no modules are loaded
The execution of insmod /lib/modules/4.4.41-gf9f6f0db2d/updates/compat/compat.ko gives no errors
but when i execute insmod /lib/modules/4.4.41-gf9f6f0db2d/updates/net/wireless/cfg80211.ko
i get a lot of errors and the loading of the module fails
I am using ti-processor-sdk-linux-am437x-evm-03.03.00.04 and the for the wilink build i used build_wl18xx.sh update R8.7_SP2
Any idea what could cause this problem?
should the kernel load the modules automaticaly during startup? or has that to be done via a script?
In attachment you can find the Kernel Boot log with the errors during the loading of the cfg80211.ko module
In attachment you can also find my config file and dts file
U-Boot 2013.10 (Oct 13 2017 - 09:42:51) I2C: ready DRAM: 512 MiB lcd_bl_init MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 SF: Detected S25FL128S_64K with page size 256 Bytes, erase size 64 KiB, total 16 MiB, mapped at 30000000 *** Warning - bad CRC, using default environment Init vbus0: 500mA@5V, OFF Init vbus1: 500mA@5V, ON Not found the LCD header IC Net: <ethaddr> not set. Validating first E-fuse MAC cpsw Hit any key to stop autoboot: 1 0 mmc1(part 0) is current device Booting from emmc reading /zImage 3916112 bytes read in 205 ms (18.2 MiB/s) reading /myir_ricoboard.dtb 55123 bytes read in 8 ms (6.6 MiB/s) Kernel image @ 0x80200000 [ 0x000000 - 0x3bc150 ] ## Flattened Device Tree blob at 80f80000 Booting using the fdt blob at 0x80f80000 Loading Device Tree to 9fb1c000, end 9fb2c752 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Initializing cgroup subsys cpu [ 0.000000] Initializing cgroup subsys cpuacct [ 0.000000] Linux version 4.4.41-gf9f6f0db2d (ronny@ronny-desktop) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 PREEMPT Fri Oct 13 12:27:16 CEST 2017 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: MYIR Rico Board [ 0.000000] cma: Reserved 24 MiB at 0x9e000000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM437x ES1.2 (sgx neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920 [ 0.000000] Kernel command line: console=ttyS0,115200n8 omapdss.def_disp=display1 omapfb.mode=display1:1024x768MR-24@60 spi-ti-qspi.enable_qspi=1 root=/dev/mmcblk0p2 rootfstype=ext4 [ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes) [ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Memory: 483604K/524288K available (7393K kernel code, 325K rwdata, 2480K rodata, 284K init, 253K bss, 16108K reserved, 24576K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB) [ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc09ac698 (9874 kB) [ 0.000000] .init : 0xc09ad000 - 0xc09f4000 ( 284 kB) [ 0.000000] .data : 0xc09f4000 - 0xc0a45560 ( 326 kB) [ 0.000000] .bss : 0xc0a47000 - 0xc0a865e0 ( 254 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] RCU kthread priority: 1. [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000 [ 0.000000] L2C-310 enabling early BRESP for Cortex-A9 [ 0.000000] OMAP L2C310: ROM does not support power control setting [ 0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled [ 0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB [ 0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000 [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000038] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000051] OMAP clocksource: timer1 at 24000000 Hz [ 0.000224] sched_clock: 64 bits at 300MHz, resolution 3ns, wraps every 2199023255551ns [ 0.000244] clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x45306eca54, max_idle_ns: 440795215369 ns [ 0.001042] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns [ 0.001054] OMAP clocksource: 32k_counter at 32768 Hz [ 0.001843] Console: colour dummy device 80x30 [ 0.001879] Calibrating delay loop... 1196.85 BogoMIPS (lpj=5984256) [ 0.090367] pid_max: default: 32768 minimum: 301 [ 0.090487] Security Framework initialized [ 0.090533] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.090546] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.091367] Initializing cgroup subsys io [ 0.091397] Initializing cgroup subsys memory [ 0.091441] Initializing cgroup subsys devices [ 0.091460] Initializing cgroup subsys freezer [ 0.091477] Initializing cgroup subsys perf_event [ 0.091492] Initializing cgroup subsys pids [ 0.091526] CPU: Testing write buffer coherency: ok [ 0.091927] Setting up static identity map for 0x80008200 - 0x80008260 [ 0.093870] devtmpfs: initialized [ 0.112848] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 0.182322] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.184636] pinctrl core: initialized pinctrl subsystem [ 0.186105] NET: Registered protocol family 16 [ 0.188090] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.210373] cpuidle: using governor ladder [ 0.240356] cpuidle: using governor menu [ 0.248258] OMAP GPIO hardware version 0.1 [ 0.252238] omap_gpio 48322000.gpio: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/display_mux_pins, deferring probe [ 0.262604] No ATAGs? [ 0.262645] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers. [ 0.262658] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.309712] edma 49000000.edma: TI EDMA DMA engine driver [ 0.315917] SCSI subsystem initialized [ 0.316315] usbcore: registered new interface driver usbfs [ 0.316392] usbcore: registered new interface driver hub [ 0.316516] usbcore: registered new device driver usb [ 0.317173] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins, deferring probe [ 0.317234] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c1_pins_default, deferring probe [ 0.317440] media: Linux media interface: v0.10 [ 0.317514] Linux video capture interface: v2.00 [ 0.317584] pps_core: LinuxPPS API ver. 1 registered [ 0.317594] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.317630] PTP clock support registered [ 0.318478] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.319006] Advanced Linux Sound Architecture Driver Initialized. [ 0.320510] clocksource: Switched to clocksource arm_global_timer [ 0.332087] NET: Registered protocol family 2 [ 0.332979] TCP established hash table entries: 4096 (order: 2, 16384 bytes) [ 0.333052] TCP bind hash table entries: 4096 (order: 2, 16384 bytes) [ 0.333110] TCP: Hash tables configured (established 4096 bind 4096) [ 0.333211] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.333234] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.333426] NET: Registered protocol family 1 [ 0.333824] RPC: Registered named UNIX socket transport module. [ 0.333839] RPC: Registered udp transport module. [ 0.333847] RPC: Registered tcp transport module. [ 0.333855] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.336771] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.336875] audit: initializing netlink subsys (disabled) [ 0.336945] audit: type=2000 audit(0.320:1): initialized [ 0.344332] VFS: Disk quotas dquot_6.6.0 [ 0.344549] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.345825] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.346698] NFS: Registering the id_resolver key type [ 0.346753] Key type id_resolver registered [ 0.346763] Key type id_legacy registered [ 0.346796] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.346813] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 0.347770] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc. [ 0.348673] fuse init (API version 7.23) [ 0.355295] io scheduler noop registered [ 0.355323] io scheduler deadline registered [ 0.355403] io scheduler cfq registered (default) [ 0.358996] pinctrl-single 44e10800.pinmux: bad data for mux unused_pins [ 0.359020] pinctrl-single 44e10800.pinmux: no pins entries for unused_pins [ 0.359161] pinctrl-single 44e10800.pinmux: 199 pins at pa f9e10800 size 796 [ 0.362157] backlight supply power not found, using dummy regulator [ 0.363414] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 0.365121] Serial: 8250/16550 driver, 6 ports, IRQ sharing enabled [ 0.367149] omap8250 44e09000.serial: No clock speed specified: using default: 48000000 [ 0.367483] console [ttyS0] disabled [ 0.367554] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250 [ 1.136817] console [ttyS0] enabled [ 1.140903] omap8250 481a6000.serial: No clock speed specified: using default: 48000000 [ 1.149270] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 31, base_baud = 3000000) is a 8250 [ 1.160233] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 1.167199] [drm] Initialized drm 1.1.0 20060810 [ 1.173795] 4832a000.dss supply vdda_video not found, using dummy regulator [ 1.180981] OMAP DSS rev 2.0 [ 1.184033] omapdss_dss 4832a000.dss: bound 4832a400.dispc (ops dispc_component_ops) [ 1.209014] brd: module loaded [ 1.219384] loop: module loaded [ 1.224463] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.233129] spi spi1.0: not using DMA for McSPI (-19) [ 1.238520] spidev spi1.0: buggy DT: spidev listed directly in DT [ 1.244721] ------------[ cut here ]------------ [ 1.249380] WARNING: CPU: 0 PID: 1 at drivers/spi/spidev.c:719 spidev_probe+0x170/0x1ac() [ 1.257610] Modules linked in: [ 1.260708] CPU: 0 PID: 1 Comm: swapper Not tainted 4.4.41-gf9f6f0db2d #1 [ 1.267526] Hardware name: Generic AM43 (Flattened Device Tree) [ 1.273529] [<c0014620>] (unwind_backtrace) from [<c00123bc>] (show_stack+0x10/0x14) [ 1.281339] [<c00123bc>] (show_stack) from [<c0030edc>] (warn_slowpath_common+0x74/0xac) [ 1.289476] [<c0030edc>] (warn_slowpath_common) from [<c0030f30>] (warn_slowpath_null+0x1c/0x24) [ 1.298321] [<c0030f30>] (warn_slowpath_null) from [<c047f608>] (spidev_probe+0x170/0x1ac) [ 1.306661] [<c047f608>] (spidev_probe) from [<c047d2b0>] (spi_drv_probe+0x7c/0xa8) [ 1.314381] [<c047d2b0>] (spi_drv_probe) from [<c040d29c>] (driver_probe_device+0x1d8/0x2a0) [ 1.322894] [<c040d29c>] (driver_probe_device) from [<c040b918>] (bus_for_each_drv+0x44/0x8c) [ 1.331483] [<c040b918>] (bus_for_each_drv) from [<c040d038>] (__device_attach+0xa0/0x104) [ 1.339792] [<c040d038>] (__device_attach) from [<c040c7c0>] (bus_probe_device+0x84/0x8c) [ 1.348027] [<c040c7c0>] (bus_probe_device) from [<c040ac90>] (device_add+0x378/0x520) [ 1.356005] [<c040ac90>] (device_add) from [<c047d104>] (spi_add_device+0x88/0x130) [ 1.363717] [<c047d104>] (spi_add_device) from [<c047ea70>] (of_register_spi_device+0x1f8/0x2e8) [ 1.372561] [<c047ea70>] (of_register_spi_device) from [<c047ef3c>] (spi_register_master+0x210/0x430) [ 1.381840] [<c047ef3c>] (spi_register_master) from [<c047f190>] (devm_spi_register_master+0x34/0x70) [ 1.391120] [<c047f190>] (devm_spi_register_master) from [<c04807bc>] (omap2_mcspi_probe+0x288/0x330) [ 1.400392] [<c04807bc>] (omap2_mcspi_probe) from [<c040e720>] (platform_drv_probe+0x50/0xb0) [ 1.408977] [<c040e720>] (platform_drv_probe) from [<c040d29c>] (driver_probe_device+0x1d8/0x2a0) [ 1.417908] [<c040d29c>] (driver_probe_device) from [<c040d3f0>] (__driver_attach+0x8c/0x90) [ 1.426404] [<c040d3f0>] (__driver_attach) from [<c040b9b4>] (bus_for_each_dev+0x54/0x88) [ 1.434640] [<c040b9b4>] (bus_for_each_dev) from [<c040c9a4>] (bus_add_driver+0xe8/0x1f4) [ 1.442871] [<c040c9a4>] (bus_add_driver) from [<c040d9f0>] (driver_register+0x78/0xf4) [ 1.450930] [<c040d9f0>] (driver_register) from [<c0009698>] (do_one_initcall+0x84/0x1d4) [ 1.459157] [<c0009698>] (do_one_initcall) from [<c09add98>] (kernel_init_freeable+0xf8/0x1c4) [ 1.467835] [<c09add98>] (kernel_init_freeable) from [<c06fd238>] (kernel_init+0x8/0xf8) [ 1.475987] [<c06fd238>] (kernel_init) from [<c000f778>] (ret_from_fork+0x14/0x3c) [ 1.483626] ---[ end trace e5ee0258688a0dff ]--- [ 1.490213] m25p80 spi5.0: Spansion Quad bit not set [ 1.495294] m25p80 spi5.0: Spansion quad-read not enabled [ 1.500740] m25p80 spi5.0: quad mode not supported [ 1.505573] m25p80: probe of spi5.0 failed with error -22 [ 1.570575] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [ 1.576714] davinci_mdio 4a101000.mdio: detected phy mask fffffffe [ 1.583822] libphy: 4a101000.mdio: probed [ 1.587872] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ9031 Gigabit PHY [ 1.598525] cpsw 4a100000.ethernet: Detected MACID = a8:1b:6a:c1:53:05 [ 1.605318] cpsw 4a100000.ethernet: cpts: overflow check period 850 [ 2.018854] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 2.025483] ehci-omap: OMAP-EHCI Host Controller driver [ 2.031578] dwc3 48390000.usb: otg: primary host xhci-hcd.0.auto registered [ 2.038584] dwc3 48390000.usb: otg: shared host xhci-hcd.0.auto registered [ 2.045535] dwc3 48390000.usb: otg: can't start till gadget registers [ 2.052116] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.057659] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1 [ 2.065823] xhci-hcd xhci-hcd.1.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x00210010 [ 2.074643] xhci-hcd xhci-hcd.1.auto: irq 259, io mem 0x483d0000 [ 2.080893] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 2.087719] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.095001] usb usb1: Product: xHCI Host Controller [ 2.099906] usb usb1: Manufacturer: Linux 4.4.41-gf9f6f0db2d xhci-hcd [ 2.106389] usb usb1: SerialNumber: xhci-hcd.1.auto [ 2.112145] hub 1-0:1.0: USB hub found [ 2.115968] hub 1-0:1.0: 1 port detected [ 2.120319] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller [ 2.125944] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 2 [ 2.133768] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 2.142080] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003 [ 2.148907] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 2.156189] usb usb2: Product: xHCI Host Controller [ 2.161106] usb usb2: Manufacturer: Linux 4.4.41-gf9f6f0db2d xhci-hcd [ 2.167578] usb usb2: SerialNumber: xhci-hcd.1.auto [ 2.173229] hub 2-0:1.0: USB hub found [ 2.177039] hub 2-0:1.0: 1 port detected [ 2.181739] usbcore: registered new interface driver usb-storage [ 2.187951] usbcore: registered new interface driver usbserial [ 2.193971] usbcore: registered new interface driver ftdi_sio [ 2.199794] usbserial: USB Serial support registered for FTDI USB Serial Device [ 2.207799] mousedev: PS/2 mouse device common for all mice [ 2.216354] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ 2.223893] i2c /dev entries driver [ 2.228853] usbcore: registered new interface driver uvcvideo [ 2.234746] USB Video Class driver (1.1.1) [ 2.240325] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 2.402254] ledtrig-cpu: registered to indicate activity on CPUs [ 2.408688] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1 [ 2.417087] omap-des 53701000.des: OMAP DES hw accel rev: 0.33 [ 2.426652] omap-sham 53100000.sham: hw accel on OMAP rev 0.0 [ 2.435069] usbcore: registered new interface driver usbhid [ 2.440930] usbhid: USB HID core driver [ 2.448625] remoteproc0: wkup_m3 is available [ 2.453204] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 2.462400] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 2.473024] remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2 [ 2.484510] ti-pruss 54400000.pruss: creating PRU cores and other child platform devices [ 2.492803] remoteproc0: failed to load am335x-pm-firmware.elf [ 2.498816] mmc1: MAN_BKOPS_EN bit is not set [ 2.504385] irq: no irq domain found for /ocp/pruss_wrapper@54426000/pruss@54400000/intc@54420000 ! [ 2.514305] irq: no irq domain found for /ocp/pruss_wrapper@54426000/pruss@54400000/intc@54420000 ! [ 2.524239] ti-pruss 54440000.pruss: creating PRU cores and other child platform devices [ 2.532934] mmc1: new high speed MMC card at address 0001 [ 2.539472] irq: no irq domain found for /ocp/pruss_wrapper@54426000/pruss@54440000/intc@54460000 ! [ 2.548977] mmcblk0: mmc1:0001 Q2J54A 3.64 GiB [ 2.554637] irq: no irq domain found for /ocp/pruss_wrapper@54426000/pruss@54440000/intc@54460000 ! [ 2.563831] mmcblk0boot0: mmc1:0001 Q2J54A partition 1 2.00 MiB [ 2.570113] mmcblk0boot1: mmc1:0001 Q2J54A partition 2 2.00 MiB [ 2.578469] remoteproc1: 54434000.pru0 is available [ 2.584275] remoteproc1: Note: remoteproc is still under development and considered experimental. [ 2.593442] mmcblk0: p1 p2 p3 [ 2.596754] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 2.609359] remoteproc1: Direct firmware load for am437x-pru1_0-fw failed with error -2 [ 2.617643] remoteproc1: failed to load am437x-pru1_0-fw [ 2.623158] pru-rproc 54434000.pru0: booting the PRU core manually [ 2.629373] remoteproc1: powering up 54434000.pru0 [ 2.634378] remoteproc1: Direct firmware load for am437x-pru1_0-fw failed with error -2 [ 2.642546] remoteproc1: request_firmware failed: -2 [ 2.647627] pru-rproc 54434000.pru0: rproc_boot failed [ 2.652882] remoteproc1: releasing 54434000.pru0 [ 2.657712] pru-rproc: probe of 54434000.pru0 failed with error -2 [ 2.664443] remoteproc1: 54438000.pru1 is available [ 2.669439] remoteproc1: Note: remoteproc is still under development and considered experimental. [ 2.678518] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 2.689095] remoteproc1: Direct firmware load for am437x-pru1_1-fw failed with error -2 [ 2.697308] remoteproc1: failed to load am437x-pru1_1-fw [ 2.702790] pru-rproc 54438000.pru1: booting the PRU core manually [ 2.709001] remoteproc1: powering up 54438000.pru1 [ 2.714046] remoteproc1: Direct firmware load for am437x-pru1_1-fw failed with error -2 [ 2.722219] remoteproc1: request_firmware failed: -2 [ 2.727298] pru-rproc 54438000.pru1: rproc_boot failed [ 2.732539] remoteproc1: releasing 54438000.pru1 [ 2.737354] pru-rproc: probe of 54438000.pru1 failed with error -2 [ 2.743989] remoteproc1: 54474000.pru0 is available [ 2.748985] remoteproc1: Note: remoteproc is still under development and considered experimental. [ 2.758050] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 2.768613] remoteproc1: Direct firmware load for am437x-pru0_0-fw failed with error -2 [ 2.776819] remoteproc1: failed to load am437x-pru0_0-fw [ 2.782298] pru-rproc 54474000.pru0: booting the PRU core manually [ 2.788509] remoteproc1: powering up 54474000.pru0 [ 2.793504] remoteproc1: Direct firmware load for am437x-pru0_0-fw failed with error -2 [ 2.801669] remoteproc1: request_firmware failed: -2 [ 2.806749] pru-rproc 54474000.pru0: rproc_boot failed [ 2.811985] remoteproc1: releasing 54474000.pru0 [ 2.816779] pru-rproc: probe of 54474000.pru0 failed with error -2 [ 2.823365] remoteproc1: 54478000.pru1 is available [ 2.828359] remoteproc1: Note: remoteproc is still under development and considered experimental. [ 2.837420] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 2.847965] remoteproc1: Direct firmware load for am437x-pru0_1-fw failed with error -2 [ 2.856164] remoteproc1: failed to load am437x-pru0_1-fw [ 2.861635] pru-rproc 54478000.pru1: booting the PRU core manually [ 2.867845] remoteproc1: powering up 54478000.pru1 [ 2.872840] remoteproc1: Direct firmware load for am437x-pru0_1-fw failed with error -2 [ 2.881003] remoteproc1: request_firmware failed: -2 [ 2.886081] pru-rproc 54478000.pru1: rproc_boot failed [ 2.891313] remoteproc1: releasing 54478000.pru1 [ 2.896109] pru-rproc: probe of 54478000.pru1 failed with error -2 [ 2.907573] NET: Registered protocol family 10 [ 2.913484] sit: IPv6 over IPv4 tunneling driver [ 2.919017] NET: Registered protocol family 17 [ 2.924036] Key type dns_resolver registered [ 2.928346] NET: Registered protocol family 41 [ 2.933268] omap_voltage_late_init: Voltage driver support not added [ 2.940909] PM: Cannot get wkup_m3_ipc handle [ 2.945390] ThumbEE CPU extension supported. [ 2.953063] omapdrm omapdrm.0: DMM not available, disable DMM support [ 2.961245] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 2.967902] [drm] No driver support for vblank timestamp query. [ 3.024120] Console: switching to colour frame buffer device 100x30 [ 3.047187] omapdrm omapdrm.0: fb0: omapdrm frame buffer device [ 3.080762] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0 [ 3.087519] GPIO line 168 (SelLCDorHDMI) hogged as output/high [ 3.124807] ov2659 0-0030: Sensor detection failed (3030, 0) [ 3.130790] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 200 kHz [ 3.152972] ov2659 1-0030: Sensor detection failed (3030, 0) [ 3.158732] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 200 kHz [ 3.166282] remoteproc0: powering up wkup_m3 [ 3.170976] remoteproc0: Direct firmware load for am335x-pm-firmware.elf failed with error -2 [ 3.179705] remoteproc0: request_firmware failed: -2 [ 3.184865] wkup_m3_ipc 44e11324.wkup_m3_ipc: rproc_boot failed [ 3.192863] PM: bootloader does not support rtc-only! [ 3.203514] input: gpio_keys as /devices/platform/gpio_keys/input/input0 [ 3.215708] omap_rtc 44e3e000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800) [ 3.237218] wlan-en-regulator: disabling [ 3.244058] ALSA device list: [ 3.249242] No soundcards found. [ 3.259292] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [ 3.271831] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [ 4.323109] EXT4-fs (mmcblk0p2): recovery complete [ 4.334552] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 4.348261] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 4.361412] devtmpfs: mounted [ 4.367214] Freeing unused kernel memory: 284K (c09ad000 - c09f4000) [ 4.377898] This architecture does not have kernel memory protection. [ 4.603287] systemd[1]: System time before build time, advancing clock. [ 4.667338] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available) [ 4.687604] random: systemd: uninitialized urandom read (16 bytes read, 22 bits of entropy available) [ 4.710570] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN) [ 4.741955] systemd[1]: Detected architecture arm. Welcome to [1mArago 2016.12[0m! [ 4.772214] systemd[1]: Set hostname to <am437x-evm>. [ 4.870843] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 24 bits of entropy available) [ 4.928520] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available) [ 4.946841] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available) [ 4.971076] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 25 bits of entropy available) [ 5.024853] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 27 bits of entropy available) [ 5.128821] random: systemd: uninitialized urandom read (16 bytes read, 30 bits of entropy available) [ 5.145235] random: systemd: uninitialized urandom read (16 bytes read, 30 bits of entropy available) [ 5.162583] random: systemd: uninitialized urandom read (16 bytes read, 30 bits of entropy available) [ 5.578031] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start [ 5.591309] systemd[1]: sysinit.target: Found dependency on uim-sysfs.service/start [ 5.604164] systemd[1]: sysinit.target: Found dependency on basic.target/start [ 5.616339] systemd[1]: sysinit.target: Found dependency on sysinit.target/start [ 5.628794] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job uim-sysfs.service/start [ 5.644646] systemd[1]: uim-sysfs.service: Job uim-sysfs.service/start deleted to break ordering cycle starting with sysinit.target/start [[0;1;31m SKIP [0m] Ordering cycle found, skipping uim-sysfs.service [ 5.694942] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start [ 5.708040] systemd[1]: sysinit.target: Found dependency on alignment.service/start [ 5.720940] systemd[1]: sysinit.target: Found dependency on basic.target/start [ 5.733044] systemd[1]: sysinit.target: Found dependency on sysinit.target/start [ 5.745494] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start [ 5.761256] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start [[0;1;31m SKIP [0m] Ordering cycle found, skipping alignment.service [ 5.810688] systemd[1]: Started Dispatch Password Requests to Console Directory Watch. [[0;32m OK [0m] Started Dispatch Password Requests to Console Directory Watch. [ 5.845310] systemd[1]: Listening on Journal Socket. [[0;32m OK [0m] Listening on Journal Socket. [ 5.865112] systemd[1]: Listening on udev Kernel Socket. [[0;32m OK [0m] Listening on udev Kernel Socket. [ 5.895228] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe. [[0;32m OK [0m] Listening on /dev/initctl Compatibility Named Pipe. [ 5.934560] systemd[1]: Listening on udev Control Socket. [[0;32m OK [0m] Listening on udev Control Socket. [ 5.954511] systemd[1]: Reached target Swap. [[0;32m OK [0m] Reached target Swap. [ 5.974655] systemd[1]: Reached target Remote File Systems. [[0;32m OK [0m] Reached target Remote File Systems. [ 5.995154] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [[0;32m OK [0m] Started Forward Password Requests to Wall Directory Watch. [ 6.033821] systemd[1]: Reached target Paths. [[0;32m OK [0m] Reached target Paths. [ 6.054708] systemd[1]: Listening on Journal Socket (/dev/log). [[0;32m OK [0m] Listening on Journal Socket (/dev/log). [ 6.087893] systemd[1]: Created slice User and Session Slice. [[0;32m OK [0m] Created slice User and Session Slice. [ 6.116629] systemd[1]: Listening on Syslog Socket. [[0;32m OK [0m] Listening on Syslog Socket. [ 6.146708] systemd[1]: Created slice System Slice. [[0;32m OK [0m] Created slice System Slice. [ 6.175209] systemd[1]: Reached target Slices. [[0;32m OK [0m] Reached target Slices. [ 6.200802] systemd[1]: Mounting Debug File System... Mounting Debug File System... [ 6.239834] systemd[1]: Starting Setup Virtual Console... Starting Setup Virtual Console... [ 6.320827] systemd[1]: Mounting POSIX Message Queue File System... Mounting POSIX Message Queue File System... [ 6.376451] systemd[1]: Created slice system-serial\x2dgetty.slice. [[0;32m OK [0m] Created slice system-serial\x2dgetty.slice. [ 6.413080] systemd[1]: Mounting Temporary Directory... Mounting Temporary Directory... [ 6.466216] systemd[1]: Listening on Journal Audit Socket. [[0;32m OK [0m] Listening on Journal Audit Socket. [ 6.501816] systemd[1]: Starting Journal Service... Starting Journal Service... [ 6.553133] systemd[1]: Starting Create list of required static device nodes for the current kernel... Starting Create list of required st... nodes for the current kernel... [ 6.661102] systemd[1]: Starting File System Check on Root Device... [ 6.732042] systemd[1]: Listening on Network Service Netlink Socket. Starting File System Check on Root Device... [[0;32m OK [0m] Listening on Network Service Netlink Socket. [ 6.766778] systemd[1]: Created slice system-getty.slice. [[0;32m OK [0m] Created slice system-getty.slice. [ 6.846398] systemd[1]: Starting Load Kernel Modules... Starting Load Kernel Modules... [ 6.952428] cmemk: disagrees about version of symbol module_layout [ 7.007396] systemd[1]: Mounted POSIX Message Queue File System. [[0;32m OK [0m] Mounted POSIX Message Queue File System. [ 7.031705] cryptodev: disagrees about version of symbol module_layout [ 7.049968] systemd[1]: Mounted Debug File System. [[0;32m OK [0m] Mounted Debug File System. [ 7.096057] systemd[1]: Mounted Temporary Directory. [[0;32m OK [0m] Mounted Temporary Directory. [ 7.128903] systemd[1]: Started Setup Virtual Console. [[0;32m OK [0m] Started Setup Virtual Console. [ 7.177649] systemd[1]: Started Create list of required static device nodes for the current kernel. [[0;32m OK [0m] Started Create list of required sta...ce nodes for the current kernel. [ 7.228298] systemd[1]: Started File System Check on Root Device. [[0;32m OK [0m] Started File System Check on Root Device. [ 7.258281] systemd[1]: systemd-modules-load.service: Main process exited, code=exited, status=1/FAILURE [ 7.276932] systemd[1]: Failed to start Load Kernel Modules. [[0;1;31mFAILED[0m] Failed to start Load Kernel Modules. See 'systemctl status systemd-modules-load.service' for details. [ 7.334571] systemd[1]: systemd-modules-load.service: Unit entered failed state. [ 7.347120] systemd[1]: systemd-modules-load.service: Failed with result 'exit-code'. [ 7.362529] systemd[1]: Started Journal Service. [[0;32m OK [0m] Started Journal Service. Mounting FUSE Control File System... Mounting Configuration File System... Starting Apply Kernel Variables... Starting Remount Root and Kernel File Systems... Starting Create Static Device Nodes in /dev... [ 8.382356] sch_fq_codel: disagrees about version of symbol module_layout [ 8.446434] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [[0;32m OK [0m] Mounted Configuration File System. [[0;32m OK [0m] Mounted FUSE Control File System. [[0;32m OK [0m] Started Apply Kernel Variables. [[0;32m OK [0m] Started Remount Root and Kernel File Systems. [[0;32m OK [0m] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [[0;32m OK [0m] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Coldplug all Devices... Starting Flush Journal to Persistent Storage... [[0;32m OK [0m] Mounted /var/volatile. [[0;32m OK [0m] Mounted /media/ram. [[0;32m OK [0m] Started udev Kernel Device Manager. [ 11.098948] systemd-journald[150]: Received request to flush runtime journal from PID 1 [[0;32m OK [0m] Started Flush Journal to Persistent Storage. [ 11.428340] ti_am335x_tscadc: disagrees about version of symbol module_layout [ 11.554160] virtio_ring: disagrees about version of symbol module_layout [ 11.575125] ti_am335x_tscadc: disagrees about version of symbol module_layout [[0;32m OK [0m] Started udev Coldplug all Devices. [ 11.676800] rtc_omap: disagrees about version of symbol module_layout [ 11.762396] omap_wdt: disagrees about version of symbol module_layout [ 11.799999] virtio_ring: disagrees about version of symbol module_layout [ 11.823126] ov2659: disagrees about version of symbol module_layout [ 11.851418] rtc_omap: disagrees about version of symbol module_layout [ 11.882723] ti_am335x_tscadc: disagrees about version of symbol module_layout [ 11.961043] omap_wdt: disagrees about version of symbol module_layout [ 11.984306] ov2659: disagrees about version of symbol module_layout [ 11.996821] virtio_ring: disagrees about version of symbol module_layout [ 12.023949] rtc_omap: disagrees about version of symbol module_layout [ 12.080088] ti_am335x_tscadc: disagrees about version of symbol module_layout [[0;32m OK [0m] Found device /dev/ttyS0. [ 12.151117] virtio_ring: disagrees about version of symbol module_layout [ 12.208894] rtc_omap: disagrees about version of symbol module_layout [ 12.336180] ti_am335x_tscadc: disagrees about version of symbol module_layout [ 12.383775] virtio_ring: disagrees about version of symbol module_layout Starting Load/Save Random Seed... [[0;32m OK [0m] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ 12.611481] virtio_ring: disagrees about version of symbol module_layout [ 12.706740] ov2659: disagrees about version of symbol module_layout [ 12.740052] ti_am335x_tscadc: disagrees about version of symbol module_layout [ 12.945690] can_dev: disagrees about version of symbol module_layout [ 12.956772] can_dev: disagrees about version of symbol module_layout [ 13.048077] ov2659: disagrees about version of symbol module_layout [ 13.100414] rng_core: disagrees about version of symbol module_layout [ 13.111848] am437x_vpfe: disagrees about version of symbol module_layout [ 13.124901] am437x_vpfe: disagrees about version of symbol module_layout [ 13.137108] can_dev: disagrees about version of symbol module_layout [[0;32m OK [0m] Started Load/Save Random Seed. [ 13.153608] can_dev: disagrees about version of symbol module_layout [ 13.234129] am437x_vpfe: disagrees about version of symbol module_layout [ 13.331352] extcon: disagrees about version of symbol module_layout [ 13.342231] extcon: disagrees about version of symbol module_layout [ 13.359759] rng_core: disagrees about version of symbol module_layout [ 13.380732] can_dev: disagrees about version of symbol module_layout [ 13.433129] am437x_vpfe: disagrees about version of symbol module_layout [[0;32m OK [0m] Started Create Volatile Files and Directories. [ 13.482657] can_dev: disagrees about version of symbol module_layout [ 13.524376] extcon: disagrees about version of symbol module_layout [ 13.561460] extcon: disagrees about version of symbol module_layout [ 13.665458] can_dev: disagrees about version of symbol module_layout [ 13.677210] can_dev: disagrees about version of symbol module_layout [ 13.796544] extcon: disagrees about version of symbol module_layout [ 13.827350] extcon: disagrees about version of symbol module_layout [ 13.940526] extcon: disagrees about version of symbol module_layout [ 13.984337] extcon: disagrees about version of symbol module_layout [ 14.233841] usbcore: disagrees about version of symbol module_layout [ 14.245159] omap_sham: disagrees about version of symbol module_layout [ 14.259782] usbcore: disagrees about version of symbol module_layout [ 14.271490] omap_des: disagrees about version of symbol module_layout [ 14.284125] omap_aes_driver: disagrees about version of symbol module_layout [ 14.318954] am437x_pruss_wrapper: disagrees about version of symbol module_layout [ 14.364732] pvrsrvkm: disagrees about version of symbol module_layout [ 14.413631] omap_sham: disagrees about version of symbol module_layout [ 14.454308] omap_aes_driver: disagrees about version of symbol module_layout [ 14.475275] virtio_ring: disagrees about version of symbol module_layout [ 14.557130] usbcore: disagrees about version of symbol module_layout [ 14.574203] omap_des: disagrees about version of symbol module_layout [ 14.588767] usbcore: disagrees about version of symbol module_layout [ 14.635002] virtio_ring: disagrees about version of symbol module_layout [ 14.649215] pvrsrvkm: disagrees about version of symbol module_layout [ 14.902307] am437x_pruss_wrapper: disagrees about version of symbol module_layout [ 15.048717] virtio_ring: disagrees about version of symbol module_layout [ 15.245589] virtio_ring: disagrees about version of symbol module_layout [ 15.413111] virtio_ring: disagrees about version of symbol module_layout [ 15.461509] usbcore: disagrees about version of symbol module_layout [ 15.491996] usbcore: disagrees about version of symbol module_layout Starting Network Time Synchronization... [ 15.599409] virtio_ring: disagrees about version of symbol module_layout [ 15.692228] virtio_ring: disagrees about version of symbol module_layout Starting Update UTMP about System Boot/Shutdown... [ 15.737205] usbcore: disagrees about version of symbol module_layout [ 15.751239] usbcore: disagrees about version of symbol module_layout [ 15.857543] virtio_ring: disagrees about version of symbol module_layout [ 16.014294] virtio_ring: disagrees about version of symbol module_layout [ 16.098591] usbcore: disagrees about version of symbol module_layout [ 16.112892] usbcore: disagrees about version of symbol module_layout [ 16.148239] virtio_ring: disagrees about version of symbol module_layout [ 16.229855] virtio_ring: disagrees about version of symbol module_layout [ 16.268207] usbcore: disagrees about version of symbol module_layout [ 16.281101] usbcore: disagrees about version of symbol module_layout [ 16.362930] virtio_ring: disagrees about version of symbol module_layout [ 16.440288] virtio_ring: disagrees about version of symbol module_layout [ 16.472045] virtio_ring: disagrees about version of symbol module_layout [[0;32m OK [0m] Started Network Time Synchronization. [ 16.555529] virtio_ring: disagrees about version of symbol module_layout [ 16.604703] virtio_ring: disagrees about version of symbol module_layout [ 16.648485] virtio_ring: disagrees about version of symbol module_layout [ 16.662018] pruss_intc: disagrees about version of symbol module_layout [ 16.673951] virtio_ring: disagrees about version of symbol module_layout [ 16.784484] virtio_ring: disagrees about version of symbol module_layout [ 16.791179] virtio_ring: disagrees about version of symbol module_layout [ 16.833498] virtio_ring: disagrees about version of symbol module_layout [ 16.848479] pruss_intc: disagrees about version of symbol module_layout [ 17.011373] virtio_ring: disagrees about version of symbol module_layout [ 17.032628] virtio_ring: disagrees about version of symbol module_layout [ 17.047567] virtio_ring: disagrees about version of symbol module_layout [ 17.146327] virtio_ring: disagrees about version of symbol module_layout [ 17.222613] virtio_ring: disagrees about version of symbol module_layout [ 17.342195] pruss_intc: disagrees about version of symbol module_layout [ 17.469363] pruss_intc: disagrees about version of symbol module_layout [ 17.510354] virtio_ring: disagrees about version of symbol module_layout [ 17.619313] virtio_ring: disagrees about version of symbol module_layout [ 17.785019] ti_emif_sram: disagrees about version of symbol module_layout [ 17.954505] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 17.982546] ti_emif_sram: disagrees about version of symbol module_layout [ 18.073442] FAT-fs (mmcblk0p3): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [[0;32m OK [0m] Started Update UTMP about System Boot/Shutdown. [[0;32m OK [0m] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen Backlight...htness of backlight:backlight... Starting Synchronize System and HW clocks... [[0;32m OK [0m] Reached target System Time Synchronized. [[0;32m OK [0m] Started Load/Save Screen Backlight Brightness of backlight:backlight. [[0;32m OK [0m] Started Synchronize System and HW clocks. [[0;32m OK [0m] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [[0;32m OK [0m] Reached target System Initialization. [[0;32m OK [0m] Listening on D-Bus System Message Bus Socket. [[0;32m OK [0m] Listening on dropbear.socket. [[0;32m OK [0m] Started Daily Cleanup of Temporary Directories. [[0;32m OK [0m] Reached target Timers. [[0;32m OK [0m] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [[0;32m OK [0m] Listening on RPCbind Server Activation Socket. [[0;32m OK [0m] Reached target Sockets. [[0;32m OK [0m] Reached target Basic System. [[0;32m OK [0m] Started Kernel Logging Service. Starting Avahi mDNS/DNS-SD Stack... Starting rc.pvr.service... Starting Login Service... [[0;32m OK [0m] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf. [[0;32m OK [0m] Started System Logging Service. Starting Telephony service... [ 22.065419] pvrsrvkm: disagrees about version of symbol module_layout Starting Print notice about GPLv3 packages... Starting Permit User Sessions... [[0;32m OK [0m] Started D-Bus System Message Bus. [ 22.913379] xfrm_algo: disagrees about version of symbol module_layout [[0;32m OK [0m] Started Avahi mDNS/DNS-SD Stack. [[0;32m OK [0m] Started Telephony service. Starting Network Service... [ 23.306790] bluetooth: disagrees about version of symbol module_layout [[0;32m OK [0m] Started Permit User Sessions. [[0;32m OK [0m] Started Network Service. [ 24.057788] random: nonblocking pool is initialized [ 24.092950] net eth0: initializing cpsw version 1.15 (0) [ 24.171043] net eth0: initialized cpsw ale version 1.4 [ 24.241467] net eth0: ALE Table size 1024 [ 24.394624] net eth0: phy found : id is : 0x221622 [ 24.504605] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 24.549939] xfrm_algo: disagrees about version of symbol module_layout [ 27.148568] pvrsrvkm: disagrees about version of symbol module_layout [[0;32m OK [0m] Started rc.pvr.service. Starting weston.service... [[0;32m OK [0m] Reached target Network. Starting Lightning Fast Webserver With Light System Requirements... Starting Network Name Resolution... [[0;32m OK [0m] Started Serial Getty on ttyS0. [[0;32m OK [0m] Started Getty on tty1. [[0;32m OK [0m] Started Lightning Fast Webserver With Light System Requirements. [[0;32m OK [0m] Started weston.service. [[0;32m OK [0m] Started Network Name Resolution. [[0;32m OK [0m] Started Login Service. Starting telnetd.service... [[0;32m OK [0m] Started telnetd.service. Starting thttpd.service... [[0;32m OK [0m] Started thttpd.service. Starting rng-tools.service... [[0;32m OK [0m] Started rng-tools.service. Starting matrix-gui-2.0.service... [[0;32m OK [0m] Started matrix-gui-2.0.service. Starting thermal-zone-init.service... Starting parse-ip.service... [[0;32m OK [0m] Started thermal-zone-init.service. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf binutils bison-dev bison cpp-symlinks cpp dosfstools g++-symlinks g++ gawk-dev gawk gcc-symlinks gcc gdb gdbserver gstreamer1.0-libav hidapi libcairo-perf-utils libgmp10 libidn11 libmpc3 libmpfr4 m4-dev m4 make nettle swig-dev swig If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [[0;32m OK [0m] Started Print notice about GPLv3 packages. [[0;32m OK [0m] Started parse-ip.service. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am437x-evm ttyS0 Arago 2016.12 am437x-evm ttyS0 am437x-evm login: root 7[r[999;999H[6n8root@am437x-evm:~# lsmod Module Size Used by root@am437x-evm:~# insmod /lib/modules/4.4.41-gf9f6f0db2d// updates/co mpat/compat.ko [ 121.584044] Loading modules backported from Linux version R8.7_SP2-0-g5c94cc5 [ 121.609866] Backport generated by backports.git R8.7_SP2-0-gd4777ef root@am437x-evm:~# insmod /lib/modules/4.4.41-gf9f6f0db2d/updates/ne t/wireless/cfg80211.ko [ 201.522072] cfg80211: disagrees about version of symbol __sock_create [ 201.533121] cfg80211: Unknown symbol __sock_create (err -22) [ 201.542638] cfg80211: disagrees about version of symbol skb_copy_bits [ 201.557810] cfg80211: Unknown symbol skb_copy_bits (err -22) [ 201.574009] cfg80211: disagrees about version of symbol skb_put [ 201.583952] cfg80211: Unknown symbol skb_put (err -22) [ 201.597407] cfg80211: disagrees about version of symbol dev_set_name [ 201.610891] cfg80211: Unknown symbol dev_set_name (err -22) [ 201.623346] cfg80211: disagrees about version of symbol consume_skb [ 201.633868] cfg80211: Unknown symbol consume_skb (err -22) [ 201.648053] cfg80211: disagrees about version of symbol device_initialize [ 201.662639] cfg80211: Unknown symbol device_initialize (err -22) [ 201.672762] cfg80211: disagrees about version of symbol genlmsg_put [ 201.687930] cfg80211: Unknown symbol genlmsg_put (err -22) [ 201.700068] cfg80211: disagrees about version of symbol genlmsg_multicast_allns [ 201.715080] cfg80211: Unknown symbol genlmsg_multicast_allns (err -22) [ 201.728880] cfg80211: disagrees about version of symbol netdev_err [ 201.742330] cfg80211: Unknown symbol netdev_err (err -22) [ 201.751449] cfg80211: disagrees about version of symbol device_rename [ 201.766773] cfg80211: Unknown symbol device_rename (err -22) [ 201.779095] cfg80211: disagrees about version of symbol pskb_expand_head [ 201.793243] cfg80211: Unknown symbol pskb_expand_head (err -22) [ 201.803239] cfg80211: disagrees about version of symbol kfree_skb [ 201.818272] cfg80211: Unknown symbol kfree_skb (err -22) [ 201.830035] cfg80211: disagrees about version of symbol put_device [ 201.843410] cfg80211: Unknown symbol put_device (err -22) [ 201.852512] cfg80211: disagrees about version of symbol netlink_broadcast [ 201.868554] cfg80211: Unknown symbol netlink_broadcast (err -22) [ 201.881446] cfg80211: disagrees about version of symbol net_ns_type_operations [ 201.896434] cfg80211: Unknown symbol net_ns_type_operations (err -22) [ 201.909971] cfg80211: disagrees about version of symbol __alloc_skb [ 201.923264] cfg80211: Unknown symbol __alloc_skb (err -22) [ 201.932572] cfg80211: disagrees about version of symbol inet_csk_get_port [ 201.948628] cfg80211: Unknown symbol inet_csk_get_port (err -22) [ 201.961530] cfg80211: disagrees about version of symbol kobject_uevent_env [ 201.975810] cfg80211: Unknown symbol kobject_uevent_env (err -22) [ 201.988896] cfg80211: disagrees about version of symbol __dev_get_by_index [ 202.003202] cfg80211: Unknown symbol __dev_get_by_index (err -22) [ 202.013483] cfg80211: disagrees about version of symbol init_net [ 202.028181] cfg80211: Unknown symbol init_net (err -22) [ 202.039826] cfg80211: disagrees about version of symbol skb_pull [ 202.053018] cfg80211: Unknown symbol skb_pull (err -22) [ 202.061876] cfg80211: disagrees about version of symbol device_add [ 202.077107] cfg80211: Unknown symbol device_add (err -22) [ 202.089145] cfg80211: disagrees about version of symbol netlink_unicast [ 202.103173] cfg80211: Unknown symbol netlink_unicast (err -22) [ 202.112998] cfg80211: disagrees about version of symbol dev_get_by_index [ 202.128803] cfg80211: Unknown symbol dev_get_by_index (err -22) [ 202.141581] cfg80211: disagrees about version of symbol dev_close [ 202.154570] cfg80211: Unknown symbol dev_close (err -22) [ 202.163553] cfg80211: disagrees about version of symbol skb_push [ 202.178205] cfg80211: Unknown symbol skb_push (err -22) [ 202.189998] cfg80211: disagrees about version of symbol unregister_pernet_device [ 202.205211] cfg80211: Unknown symbol unregister_pernet_device (err -22) [ 202.219233] cfg80211: disagrees about version of symbol device_del [ 202.232712] cfg80211: Unknown symbol device_del (err -22) [ 202.241884] cfg80211: disagrees about version of symbol __pskb_pull_tail [ 202.257883] cfg80211: Unknown symbol __pskb_pull_tail (err -22) [ 202.270699] cfg80211: disagrees about version of symbol __netdev_alloc_skb [ 202.285060] cfg80211: Unknown symbol __netdev_alloc_skb (err -22) [ 202.295320] cfg80211: disagrees about version of symbol skb_trim [ 202.310030] cfg80211: Unknown symbol skb_trim (err -22) [ 202.321838] cfg80211: disagrees about version of symbol __put_net [ 202.332066] cfg80211: Unknown symbol __put_net (err -22) [ 202.345778] cfg80211: disagrees about version of symbol get_net_ns_by_pid [ 202.360014] cfg80211: Unknown symbol get_net_ns_by_pid (err -22) [ 202.373090] cfg80211: disagrees about version of symbol __genl_register_family [ 202.385207] cfg80211: Unknown symbol __genl_register_family (err -22) [ 202.400783] cfg80211: disagrees about version of symbol sock_release [ 202.414226] cfg80211: Unknown symbol sock_release (err -22) [ 202.423610] cfg80211: disagrees about version of symbol dev_change_net_namespace [ 202.440715] cfg80211: Unknown symbol dev_change_net_namespace (err -22) [ 202.454706] cfg80211: disagrees about version of symbol genl_unregister_family [ 202.469657] cfg80211: Unknown symbol genl_unregister_family (err -22) [ 202.485134] cfg80211: disagrees about version of symbol register_pernet_device [ 202.500221] cfg80211: Unknown symbol register_pernet_device (err -22) [ 202.513784] cfg80211: disagrees about version of symbol get_net_ns_by_fd [ 202.525025] cfg80211: Unknown symbol get_net_ns_by_fd (err -22) insmod: ERROR: could not insert module /lib/modules/4.4.41-gf9f6f0db2d/updates/net/wireless/cfg80211.ko: Invalid parameters root@am437x-evm:~#
/* * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ * Copyright (C) 2015 Pavel Pisa PiKRON.com - http://www.pikron.com/ * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License version 2 as * published by the Free Software Foundation. */ /* AM437x Myir Rico Board */ /dts-v1/; #include "am4372.dtsi" #include <dt-bindings/pinctrl/am43xx.h> #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/gpio/gpio.h> / { model = "MYIR Rico Board"; compatible = "myir,ricoboard","ti,am4372","ti,am43"; aliases { display0 = &lcd0; serial3 = &uart3; serial5 = &uart5; spi1 = &spi0; spi5 = &qspi; }; evm_v3_3d: fixedregulator-v3_3d { compatible = "regulator-fixed"; regulator-name = "evm_v3_3d"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; enable-active-high; }; vtt_fixed: fixedregulator-vtt { compatible = "regulator-fixed"; regulator-name = "vtt_fixed"; regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; regulator-always-on; regulator-boot-on; enable-active-high; gpio = <&gpio5 7 GPIO_ACTIVE_HIGH>; }; wlan_en_reg: fixedregulator@2 { compatible = "regulator-fixed"; regulator-name = "wlan-en-regulator"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; startup-delay-us = <70000>; /* WLAN_EN GPIO for this board - Bank3, pin2 */ gpio = <&gpio3 2 GPIO_ACTIVE_HIGH>; enable-active-high; }; lcd_bl: backlight { compatible = "pwm-backlight"; pwms = <&ecap0 0 50000 PWM_POLARITY_INVERTED>; brightness-levels = <0 51 53 56 62 75 101 152 255>; default-brightness-level = <8>; }; /* Gpio keys, MYiR */ gpio_keys { compatible = "gpio-keys"; #address-cells = <1>; #size-cells = <0>; pinctrl-names = "default"; pinctrl-0 = <&keys_pins_default>; user_key1 { label = "user_key1"; gpios = <&gpio5 11 GPIO_ACTIVE_HIGH>; linux,code = <102>; gpio-key,wakeup; }; user_key2 { label = "user_key2"; gpios = <&gpio5 13 GPIO_ACTIVE_HIGH>; linux,code = <158>; gpio-key,wakeup; }; }; /* Gpio leds, MYiR */ gpio_leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&leds_pins_default>; status_led0 { label = "status_led0"; gpios = <&gpio1 24 GPIO_ACTIVE_LOW>; linux,default-trigger = "heartbeat"; }; status_led1 { label = "status_led1"; gpios = <&gpio1 25 GPIO_ACTIVE_LOW>; default-state = "off"; }; status_led2 { label = "status_led2"; gpios = <&gpio1 26 GPIO_ACTIVE_LOW>; default-state = "off"; }; status_led3 { label = "status_led3"; gpios = <&gpio1 27 GPIO_ACTIVE_LOW>; default-state = "off"; }; }; lcd0: display { compatible = "osddisplays,osd057T0559-34ts", "panel-dpi"; label = "lcd"; backlight = <&lcd_bl>; panel-timing { clock-frequency = <33000000>; hactive = <800>; vactive = <480>; hfront-porch = <210>; hback-porch = <16>; hsync-len = <30>; vback-porch = <10>; vfront-porch = <22>; vsync-len = <13>; hsync-active = <0>; vsync-active = <0>; de-active = <1>; pixelclk-active = <1>; }; port { lcd_in: endpoint { remote-endpoint = <&dpi_out>; }; }; }; /* fixed 24MHz oscillator */ refclk: oscillator { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <24000000>; }; /* fixed 32k external oscillator clock */ clk_32k_rtc: clk_32k_rtc { #clock-cells = <0>; compatible = "fixed-clock"; clock-frequency = <32768>; }; sound0: sound@0 { status = "disabled"; compatible = "simple-audio-card"; simple-audio-card,name = "AM437x-GP-EVM"; simple-audio-card,widgets = "Headphone", "Headphone Jack", "Line", "Line In"; simple-audio-card,routing = "Headphone Jack", "HPLOUT", "Headphone Jack", "HPROUT", "LINE1L", "Line In", "LINE1R", "Line In"; simple-audio-card,format = "dsp_b"; /* simple-audio-card,bitclock-master = <&sound0_master>; */ /* simple-audio-card,frame-master = <&sound0_master>; */ simple-audio-card,bitclock-inversion; simple-audio-card,cpu { sound-dai = <&mcasp1>; system-clock-frequency = <12000000>; }; /* Not directly available on RICO board * sound0_master: simple-audio-card,codec { * sound-dai = <&tlv320aic3106>; * system-clock-frequency = <12000000>; *}; */ }; audio_mstrclk: mclk_osc { compatible = "fixed-clock"; #clock-cells = <0>; clock-frequency = <12000000>; }; }; &am43xx_pinmux { pinctrl-names = "default"; pinctrl-0 = <&ddr3_vtt_toggle_default &unused_pins &debugss_pins>; ddr3_vtt_toggle_default: ddr_vtt_toggle_default { pinctrl-single,pins = < 0x25C (DS0_PULL_UP_DOWN_EN | PIN_OUTPUT_PULLUP | DS0_FORCE_OFF_MODE | MUX_MODE7) /* spi0_cs0.gpio5_7 */ >; }; i2c0_pins: i2c0_pins { pinctrl-single,pins = < 0x188 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_sda.i2c0_sda */ 0x18c (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* i2c0_scl.i2c0_scl */ >; }; i2c1_pins_default: i2c1_pins_default { pinctrl-single,pins = < 0x240 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE1) /* gpio5_10.i2c1_scl */ 0x248 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE1) /* gpio5_12.i2c1_sda */ >; }; i2c1_pins_sleep: i2c1_pins_sleep { pinctrl-single,pins = < 0x240 (PIN_INPUT_PULLUP | MUX_MODE7) 0x248 (PIN_INPUT_PULLUP | MUX_MODE7) >; }; mmc1_pins_default: mmc1_pins_default { pinctrl-single,pins = < 0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */ 0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */ 0x0f0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */ 0x0f4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */ 0x0f8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */ 0x0fc (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */ 0x160 (PIN_INPUT | MUX_MODE7) /* spi0_cs1.gpio0_6 */ >; }; mmc1_pins_sleep: mmc1_pins_sleep { pinctrl-single,pins = < 0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* mmc0_clk.mmc0_clk */ 0x104 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* mmc0_cmd.mmc0_cmd */ 0x0f0 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* mmc0_dat0.mmc0_dat0 */ 0x0f4 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* mmc0_dat1.mmc0_dat1 */ 0x0f8 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* mmc0_dat2.mmc0_dat2 */ 0x0fc (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* mmc0_dat3.mmc0_dat3 */ 0x160 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* mmc0_sdcd.mmc0_sdcd */ >; }; /* wl12xx/wl18xx card enable/irq GPIOs. */ wlan_pins_default: pinmux_wlan_pins_default { pinctrl-single,pins = < 0x110 ( PIN_OUTPUT_PULLDOWN | MUX_MODE7 ) /* WL_EN (B13) mii1_rx_er.gpio3[2] */ 0x10c ( PIN_INPUT | WAKEUP_ENABLE | MUX_MODE7 ) /* WL_IRQ (B14) mii1_crs.gpio3[1] */ 0x23c ( PIN_OUTPUT_PULLDOWN | MUX_MODE7 ) /*BT_EN (F24) gpio5_9.gpio5[9] */ >; }; wlan_pins_sleep: pinmux_wlan_pins_sleep { pinctrl-single,pins = < 0x110 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* WL_EN (B13) mii1_rx_er.gpio3[2] */ 0x10C (PIN_INPUT | MUX_MODE7) /* WL_IRQ (B14) mii1_crs.gpio3[1] */ 0x23C (PIN_OUTPUT_PULLUP | MUX_MODE7) /*BT_EN (F24) gpio5_9.gpio5[9] */ >; }; ecap0_pins_default: backlight_pins_default { pinctrl-single,pins = < 0x164 MUX_MODE0 /* eCAP0_in_PWM0_out.eCAP0_in_PWM0_out MODE0 */ >; }; ecap0_pins_sleep: backlight_pins_sleep { pinctrl-single,pins = < 0x164 (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; cpsw_default: cpsw_default { pinctrl-single,pins = < /* Slave 1 */ 0x114 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txen.rgmii1_txen */ 0x118 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxdv.rgmii1_rxctl */ 0x11c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_txd3 */ 0x120 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_txd2 */ 0x124 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_txd1 */ 0x128 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_txd0 */ 0x12c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txclk.rmii1_tclk */ 0x130 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxclk.rmii1_rclk */ 0x134 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rxd3 */ 0x138 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rxd2 */ 0x13c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rxd1 */ 0x140 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rxd0 */ >; }; cpsw_sleep: cpsw_sleep { pinctrl-single,pins = < /* Slave 1 reset value */ 0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x134 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) 0x138 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) 0x13c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) 0x140 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < /* MDIO */ 0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ 0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ >; }; davinci_mdio_sleep: davinci_mdio_sleep { pinctrl-single,pins = < /* MDIO reset value */ 0x148 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) 0x14c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) >; }; nand_flash_x8_default: nand_flash_x8_default { pinctrl-single,pins = < 0x0 (PIN_INPUT | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */ 0x4 (PIN_INPUT | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */ 0x8 (PIN_INPUT | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */ 0xc (PIN_INPUT | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */ 0x10 (PIN_INPUT | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */ 0x14 (PIN_INPUT | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */ 0x18 (PIN_INPUT | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */ 0x1c (PIN_INPUT | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */ 0x70 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */ 0x74 (PIN_OUTPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpmc_wpn */ 0x7c (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */ 0x90 (PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */ 0x94 (PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */ 0x98 (PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */ 0x9c (PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */ >; }; nand_flash_x8_sleep: nand_flash_x8_sleep { pinctrl-single,pins = < 0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpmc_ad0 */ 0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpmc_ad1 */ 0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpmc_ad2 */ 0xc (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpmc_ad3 */ 0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpmc_ad4 */ 0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpmc_ad5 */ 0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpmc_ad6 */ 0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpmc_ad7 */ 0x70 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_wait0.gpmc_wait0 */ 0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wpn.gpmc_wpn */ 0x7c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_csn0.gpmc_csn0 */ 0x90 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_advn_ale.gpmc_advn_ale */ 0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_oen_ren.gpmc_oen_ren */ 0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_wen.gpmc_wen */ 0x9c (PIN_INPUT | PULL_DISABLE | MUX_MODE7) /* gpmc_be0n_cle.gpmc_be0n_cle */ >; }; dss_pins_default: dss_pins_default { pinctrl-single,pins = < 0x020 (PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 8 -> DSS DATA 23 */ 0x024 (PIN_OUTPUT_PULLUP | MUX_MODE1) 0x028 (PIN_OUTPUT_PULLUP | MUX_MODE1) 0x02c (PIN_OUTPUT_PULLUP | MUX_MODE1) 0x030 (PIN_OUTPUT_PULLUP | MUX_MODE1) 0x034 (PIN_OUTPUT_PULLUP | MUX_MODE1) 0x038 (PIN_OUTPUT_PULLUP | MUX_MODE1) 0x03c (PIN_OUTPUT_PULLUP | MUX_MODE1) /*gpmc ad 15 -> DSS DATA 16 */ 0x0a0 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 0 */ 0x0a4 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0a8 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0ac (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0b0 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0b4 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0b8 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0bc (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0c0 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0c4 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0c8 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0cc (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0d0 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0d4 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0d8 (PIN_OUTPUT_PULLUP | MUX_MODE0) 0x0dc (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS DATA 15 */ 0x0e0 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS VSYNC */ 0x0e4 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS HSYNC */ 0x0e8 (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS PCLK */ 0x0ec (PIN_OUTPUT_PULLUP | MUX_MODE0) /* DSS AC BIAS EN */ >; }; dss_pins_sleep: dss_pins_sleep { pinctrl-single,pins = < 0x020 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x024 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x028 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x02c (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x030 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x034 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x038 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x03c (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0a0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0a4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0a8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0ac (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0b0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0b4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0b8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0bC (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0c0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0c4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0c8 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0cc (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0d0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0d4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0d8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | PULL_DISABLE | MUX_MODE7) 0x0dc (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0e0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0e4 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0e8 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) 0x0ec (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; display_mux_pins: display_mux_pins { pinctrl-single,pins = < /* GPIO 5_8 to select LCD / HDMI */ 0x238 (PIN_OUTPUT_PULLUP | MUX_MODE7) >; }; dcan0_default: dcan0_default_pins { pinctrl-single,pins = < 0x178 (PIN_OUTPUT | MUX_MODE2) /* uart1_ctsn.d_can0_tx */ 0x17c (PIN_INPUT_PULLUP | MUX_MODE2) /* uart1_rtsn.d_can0_rx */ >; }; dcan0_sleep: dcan0_sleep_pins { pinctrl-single,pins = < 0x178 (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_ctsn.gpio0_12 */ 0x17c (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_rtsn.gpio0_13 */ >; }; dcan1_default: dcan1_default_pins { pinctrl-single,pins = < 0x180 (PIN_OUTPUT | MUX_MODE2) /* uart1_rxd.d_can1_tx */ 0x184 (PIN_INPUT_PULLUP | MUX_MODE2) /* uart1_txd.d_can1_rx */ >; }; dcan1_sleep: dcan1_sleep_pins { pinctrl-single,pins = < 0x180 (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_rxd.gpio0_14 */ 0x184 (PIN_INPUT_PULLUP | MUX_MODE7) /* uart1_txd.gpio0_15 */ >; }; vpfe0_pins_default: vpfe0_pins_default { pinctrl-single,pins = < /*0x270 (PIN_OUTPUT_PULLUP | MUX_MODE3) */ /* xdma_event_intr0.clkout1 mode 3*/ 0x1B0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_hd mode 0*/ 0x1B4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_vd mode 0*/ 0x1B8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_field mode 0*/ 0x1BC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_wen mode 0*/ 0x1C0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_pclk mode 0*/ 0x1C4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data8 mode 0*/ 0x1C8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data9 mode 0*/ 0x208 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data0 mode 0*/ 0x20C (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data1 mode 0*/ 0x210 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data2 mode 0*/ 0x214 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data3 mode 0*/ 0x218 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data4 mode 0*/ 0x21C (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data5 mode 0*/ 0x220 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data6 mode 0*/ 0x224 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam0_data7 mode 0*/ >; }; vpfe0_pins_sleep: vpfe0_pins_sleep { pinctrl-single,pins = < 0x1B0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_hd mode 0*/ 0x1B4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_vd mode 0*/ 0x1B8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_field mode 0*/ 0x1BC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_wen mode 0*/ 0x1C0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_pclk mode 0*/ 0x1C4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data8 mode 0*/ 0x1C8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data9 mode 0*/ 0x208 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data0 mode 0*/ 0x20C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data1 mode 0*/ 0x210 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data2 mode 0*/ 0x214 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data3 mode 0*/ 0x218 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data4 mode 0*/ 0x21C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data5 mode 0*/ 0x220 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data6 mode 0*/ 0x224 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam0_data7 mode 0*/ >; }; vpfe1_pins_default: vpfe1_pins_default { pinctrl-single,pins = < /* 0x270 (PIN_OUTPUT_PULLUP | MUX_MODE3) */ /* xdma_event_intr0.clkout1 mode 3*/ 0x1CC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data9 mode 0*/ 0x1D0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data8 mode 0*/ 0x1D4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_hd mode 0*/ 0x1D8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_vd mode 0*/ 0x1DC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_pclk mode 0*/ 0x1E0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_field mode 0*/ 0x1E4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_wen mode 0*/ 0x1E8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data0 mode 0*/ 0x1EC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data1 mode 0*/ 0x1F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data2 mode 0*/ 0x1F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data3 mode 0*/ 0x1F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data4 mode 0*/ 0x1FC (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data5 mode 0*/ 0x200 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data6 mode 0*/ 0x204 (PIN_INPUT_PULLUP | MUX_MODE0) /* cam1_data7 mode 0*/ >; }; vpfe1_pins_sleep: vpfe1_pins_sleep { pinctrl-single,pins = < 0x1CC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data9 mode 0*/ 0x1D0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data8 mode 0*/ 0x1D4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_hd mode 0*/ 0x1D8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_vd mode 0*/ 0x1DC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_pclk mode 0*/ 0x1E0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_field mode 0*/ 0x1E4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_wen mode 0*/ 0x1E8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data0 mode 0*/ 0x1EC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data1 mode 0*/ 0x1F0 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data2 mode 0*/ 0x1F4 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data3 mode 0*/ 0x1F8 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data4 mode 0*/ 0x1FC (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data5 mode 0*/ 0x200 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data6 mode 0*/ 0x204 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) /* cam1_data7 mode 0*/ >; }; uart3_pins_default: uart3_pins_default { pinctrl-single,pins = < 0x228 (PIN_INPUT | MUX_MODE0) /* uart3_rxd.uart3_rxd */ 0x22c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_txd.uart3_txd */ /* 0x230 (PIN_INPUT_PULLUP | MUX_MODE0) */ /* uart3_ctsn.uart3_ctsn */ /* 0x234 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) */ /* uart3_rtsn.uart3_rtsn */ >; }; uart3_pins_sleep: uart3_pins_sleep { pinctrl-single,pins = < 0x228 (PIN_INPUT | MUX_MODE0) /* uart3_rxd.uart3_rxd */ 0x22c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart3_txd.uart3_txd */ /* 0x230 (PIN_INPUT_PULLUP | MUX_MODE0) */ /* uart3_ctsn.uart3_ctsn */ /* 0x234 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) */ /* uart3_rtsn.uart3_rtsn */ >; }; spi0_pins_default: spi0_pins_default { pinctrl-single,pins = < 0x150 (PIN_OUTPUT | MUX_MODE0 | INPUT_EN) /* spi0_clk */ 0x154 (PIN_OUTPUT | MUX_MODE0) /* spi0_d0/mosi */ 0x158 (PIN_INPUT_PULLUP | MUX_MODE0) /* spi0_d1/miso */ 0x15C (PIN_OUTPUT | MUX_MODE0) /* spi0_cs0 */ >; }; spi0_pins_sleep: spi0_pins_sleep { pinctrl-single,pins = < 0x150 (PIN_INPUT_PULLUP | MUX_MODE7) /* spi0_clk */ 0x154 (PIN_INPUT_PULLUP | MUX_MODE7) /* spi0_d0/mosi */ 0x158 (PIN_INPUT_PULLUP | MUX_MODE7) /* spi0_d1/miso */ 0x15C (PIN_INPUT_PULLUP | MUX_MODE7) /* spi0_cs0 */ >; }; /* Qspi, MYiR */ qspi_pins_default: qspi_pins_default { pinctrl-single,pins = < 0x7c (PIN_OUTPUT_PULLUP | MUX_MODE3) /* gpmc_csn0.qspi_csn */ 0x88 (PIN_OUTPUT | MUX_MODE2) /* gpmc_csn3.qspi_clk */ 0x90 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_advn_ale.qspi_d0 */ 0x94 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_oen_ren.qspi_d1 */ 0x98 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_wen.qspi_d2 */ 0x9c (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_be0n_cle.qspi_d3 */ >; }; qspi_pins_sleep: qspi_pins_sleep{ pinctrl-single,pins = < 0x7c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x90 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x9c (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; /* eeprom, MYiR */ eeprom_wp_pin: eeprom_wp_pin { pinctrl-single,pins = < 0x2a4 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* emu0.gpio3_7 */ >; }; mcasp1_pins: mcasp1_pins { pinctrl-single,pins = < 0x108 (PIN_OUTPUT_PULLDOWN | MUX_MODE4) /* mii1_col.mcasp1_axr2 */ 0x10c (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_crs.mcasp1_aclkx */ 0x110 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* mii1_rxerr.mcasp1_fsx */ 0x144 (PIN_INPUT_PULLDOWN | MUX_MODE4) /* rmii1_ref_clk.mcasp1_axr3 */ >; }; mcasp1_sleep_pins: mcasp1_sleep_pins { pinctrl-single,pins = < 0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x10c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x110 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x144 (PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; emmc_pins_default: emmc_pins_default { pinctrl-single,pins = < 0x00 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */ 0x04 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */ 0x08 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */ 0x0c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */ 0x10 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */ 0x14 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */ 0x18 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */ 0x1c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */ 0x80 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */ 0x84 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */ >; }; emmc_pins_sleep: emmc_pins_sleep { pinctrl-single,pins = < 0x00 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad0.gpio1_0 */ 0x04 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad1.gpio1_1 */ 0x08 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad2.gpio1_2 */ 0x0c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad3.gpio1_3 */ 0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad4.gpio1_4 */ 0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad5.gpio1_5 */ 0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad6.gpio1_6 */ 0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad7.gpio1_7 */ 0x80 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn1.gpio1_30 */ 0x84 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_csn2.gpio1_31 */ >; }; uart0_pins_default: uart0_pins_default { pinctrl-single,pins = < /* 0x168 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE0) */ /* uart0_ctsn.unused */ /* 0x16C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE0) */ /* uart0_rtsn.unused */ 0x170 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_rxd.uart0_rxd */ 0x174 (PIN_INPUT | PULL_DISABLE | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */ >; }; uart0_pins_sleep: uart0_pins_sleep { pinctrl-single,pins = < /* 0x168 (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) */ /* uart0_ctsn.unused */ /* 0x16C (DS0_PULL_UP_DOWN_EN | INPUT_EN | MUX_MODE7) */ /* uart0_rtsn.unused */ 0x170 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_rxd.uart0_rxd */ 0x174 (PIN_INPUT_PULLDOWN | SLEWCTRL_FAST | DS0_PULL_UP_DOWN_EN | MUX_MODE0) /* uart0_txd.uart0_txd */ >; }; keys_pins_default: keys_pins_default { pinctrl-single,pins = < 0x244 (PIN_OUTPUT | MUX_MODE7) /* gpio5_11.gpio5_11 */ 0x24c (PIN_OUTPUT | MUX_MODE7) /* gpio5_13.gpio5_13 */ >; }; leds_pins_default: leds_pins_default { pinctrl-single,pins = < 0x60 (PIN_OUTPUT | MUX_MODE7) /* gpmc_a8.gpio1_24 */ 0x64 (PIN_OUTPUT | MUX_MODE7) /* gpmc_a9.gpio1_25 */ 0x68 (PIN_OUTPUT | MUX_MODE7) /* gpmc_a10.gpio1_26 */ 0x6c (PIN_OUTPUT | MUX_MODE7) /* gpmc_a11.gpio1_27 */ >; }; usb1_pins_default: usb1_pins_default { pinctrl-single,pins = < 0x2c0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE0) >; }; usb1_pins_sleep: usb1_pins_sleep { pinctrl-single,pins = < 0x2c0 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; usb2_pins_default: usb2_pins_default { pinctrl-single,pins = < 0x2c4 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE0) >; }; usb2_pins_sleep: usb2_pins_sleep { pinctrl-single,pins = < 0x2c4 (DS0_PULL_UP_DOWN_EN | PIN_INPUT_PULLDOWN | MUX_MODE7) >; }; unused_pins: unused_pins { pinctrl-single,pins = < /* 0x2C8 (PIN_INPUT_PULLDOWN) */ /* 0x2D4 (PIN_INPUT_PULLDOWN) */ /* 0x2D8 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2DC (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2E0 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2E4 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2E8 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2EC (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2F0 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2F4 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2F8 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x2FC (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x300 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x304 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x308 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x30C (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x310 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x314 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x318 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* 0x150 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi0_sclk */ /* 0x154 (PIN_INPUT_PULLDOWN | MUX_MODE0) */ /* spi0_d0 */ /* 0x23C (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpio5_9 */ /* 0x250 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi4_sclk */ /* 0x254 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi4_d0 */ >; }; /* Unconfigured pins which are used on Rico Board */ /* 0x260 (PIN_INPUT | PULL_DISABLE | MUX_MODE7) */ /* spi2_sclk.gpio3_24.gpio0_22.hdmi_intn */ /* 0x27C (PIN_INPUT | PULL_DISABLE) */ /* nresetin_out */ /* 0x50 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a4.gpio1_20.CAM0_PWDN */ /* 0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a5.gpio1_21.CAM0_RST */ /* 0x40 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a0.gpio1_16.CAM1_PWDN */ /* 0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* gpmc_a6.gpio1_22.CAM1_RST */ /* 0x158 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi0_d1.gpio0_4 */ /* 0x15c (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi0_cs0.i2c1_scl */ /* 0x268 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi2_d1.gpio0_21/gpio3_23.TP_RESET */ /* 0x270 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* xdma_evt_intr0.CLKOUT1 */ /* 0x258 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* spi4_d1.gpio5_6 */ /* 0x278 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* clkreq.gpio0_24.LOWPOWERn */ /* 0x190 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* mcasp0_aclkx */ /* 0x194 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* mcasp0_fsx */ /* 0x198 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* mcasp0_axr0 */ /* 0x19C (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* mcasp0_ahclkr */ /* 0x1A0 (PIN_INPUT_PULLDOWN | MUX_MODE7) */ /* mcasp0_aclkr */ debugss_pins: pinmux_debugss_pins { pinctrl-single,pins = < 0x290 (PIN_INPUT_PULLDOWN) 0x294 (PIN_INPUT_PULLDOWN) 0x298 (PIN_INPUT_PULLDOWN) 0x29C (PIN_INPUT_PULLDOWN) 0x2A0 (PIN_INPUT_PULLDOWN) 0x2A4 (PIN_INPUT_PULLDOWN) 0x2A8 (PIN_INPUT_PULLDOWN) >; }; }; &i2c0 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins>; clock-frequency = <200000>; tps65218: tps65218@24 { reg = <0x24>; compatible = "ti,tps65218"; interrupts = <GIC_SPI 7 IRQ_TYPE_NONE>; /* NMIn */ interrupt-controller; #interrupt-cells = <2>; dcdc1: regulator-dcdc1 { compatible = "ti,tps65218-dcdc1"; regulator-name = "vdd_core"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1144000>; regulator-boot-on; regulator-always-on; }; dcdc2: regulator-dcdc2 { compatible = "ti,tps65218-dcdc2"; regulator-name = "vdd_mpu"; regulator-min-microvolt = <912000>; regulator-max-microvolt = <1378000>; regulator-boot-on; regulator-always-on; }; dcdc3: regulator-dcdc3 { compatible = "ti,tps65218-dcdc3"; regulator-name = "vdcdc3"; /* powers VDDS_DDR */ regulator-min-microvolt = <1500000>; regulator-max-microvolt = <1500000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; regulator-state-disk { regulator-off-in-suspend; }; }; dcdc5: regulator-dcdc5 { compatible = "ti,tps65218-dcdc5"; regulator-name = "v1_0bat"; regulator-min-microvolt = <1000000>; regulator-max-microvolt = <1000000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; dcdc6: regulator-dcdc6 { compatible = "ti,tps65218-dcdc6"; regulator-name = "v1_8bat"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; regulator-state-mem { regulator-on-in-suspend; }; }; ldo1: regulator-ldo1 { compatible = "ti,tps65218-ldo1"; regulator-min-microvolt = <1800000>; regulator-max-microvolt = <1800000>; regulator-boot-on; regulator-always-on; }; }; ov2659@30 { compatible = "ovti,ov2659"; reg = <0x30>; clocks = <&audio_mstrclk>; clock-names = "xvclk"; port { ov2659_0: endpoint { remote-endpoint = <&vpfe0_ep>; link-frequencies = /bits/ 64 <70000000>; }; }; }; cat24c256@50 { compatible = "24c256"; reg = <0x50>; pagesize = <64>; }; }; &i2c1 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&i2c1_pins_default>; pinctrl-1 = <&i2c1_pins_sleep>; clock-frequency = <200000>; ov2659@30 { compatible = "ovti,ov2659"; reg = <0x30>; clocks = <&audio_mstrclk>; clock-names = "xvclk"; port { ov2659_1: endpoint { remote-endpoint = <&vpfe1_ep>; link-frequencies = /bits/ 64 <70000000>; }; }; }; }; &epwmss0 { status = "okay"; }; &tscadc { status = "okay"; adc { ti,adc-channels = <0 1 2 3 4 5 6 7>; }; }; &ecap0 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&ecap0_pins_default>; pinctrl-1 = <&ecap0_pins_sleep>; }; &gpio0 { status = "okay"; }; &gpio1 { status = "okay"; }; &gpio2 { status = "okay"; }; &gpio3 { status = "okay"; }; &gpio4 { status = "okay"; }; &gpio5 { status = "okay"; pinctrl-names = "default"; pinctrl-0 = <&display_mux_pins>; p8 { /* * SelLCDorHDMI selects between display and audio paths: * Low: HDMI display with audio via HDMI * High: LCD display with analog audio via aic3111 codec */ gpio-hog; gpios = <8 GPIO_ACTIVE_HIGH>; output-high; line-name = "SelLCDorHDMI"; }; }; /* Enable qspi, 16MB S25FL128S norflash, MYiR */ &qspi { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&qspi_pins_default>; pinctrl-1 = <&qspi_pins_sleep>; spi-max-frequency = <24000000>; /* Export SPI MTD device to user-space for testing spidev4mtd@0 { spi-max-frequency = <24000000>; compatible = "spidev"; reg = <0>; }; */ m25p80@0 { /*"s25fl256s1", "spansion,s25fl128s", "spansion,m25p80"*/ /* compatible = "s25fl256s1", "jedec,spi-nor"; */ compatible = "jedec,spi-nor"; spi-max-frequency = <24000000>; reg = <0>; spi-cpol; spi-cpha; spi-tx-bus-width = <1>; spi-rx-bus-width = <4>; #address-cells = <1>; #size-cells = <1>; /* MTD partition table. * The ROM checks the first 512KiB * for a valid file to boot(XIP). */ partition@0 { label = "QSPI.U_BOOT"; reg = <0x00000000 0x000080000>; }; partition@1 { label = "QSPI.U_BOOT.backup"; reg = <0x00080000 0x00080000>; }; partition@2 { label = "QSPI.U_BOOT_ENV"; reg = <0x00100000 0x00020000>; }; partition@3 { label = "QSPI.U-BOOT-ENV.backup"; reg = <0x00120000 0x00020000>; }; partition@4 { label = "QSPI.U-BOOT-DEVICETREE"; reg = <0x00140000 0x00010000>; }; partition@5 { label = "QSPI.KERNEL"; reg = <0x00150000 0x0500000>; }; partition@6 { label = "QSPI.FILESYSTEM"; reg = <0x00650000 0x9B0000>; }; }; }; /* eMMC sits on mmc2 */ &mmc2 { status = "okay"; vmmc-supply = <&evm_v3_3d>; bus-width = <8>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&emmc_pins_default>; pinctrl-1 = <&emmc_pins_sleep>; ti,non-removable; }; &mmc1 { status = "okay"; vmmc-supply = <&wlan_en_reg>; bus-width = <4>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mmc1_pins_default>; pinctrl-1 = <&mmc1_pins_sleep>; ti,non-removable; ti,needs-special-hs-handling; cap-power-off-card; keep-power-in-suspend; #address-cells = <1>; #size-cells = <0>; wlcore: wlcore@0 { compatible = "ti,wl1835"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&wlan_pins_default>; pinctrl-1 = <&wlan_pins_sleep>; reg = <2>; interrupt-parent = <&gpio3>; interrupts = <1 IRQ_TYPE_EDGE_RISING>; }; }; &uart3 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart3_pins_default>; pinctrl-1 = <&uart3_pins_sleep>; }; &spi0 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&spi0_pins_default>; pinctrl-1 = <&spi0_pins_sleep>; ti,pindir-d0-out-d1-in = <1>; spidev@0 { compatible = "spidev"; /* compatible = "rohm,dh2228fv"; */ reg = <0>; #address-cells = <1>; #size-cells = <0>;// spi-max-frequency = <1000000>; /* spi-cpha; */ }; }; &usb2_phy1 { status = "okay"; }; &usb1 { dr_mode = "otg"; status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&usb1_pins_default>; pinctrl-1 = <&usb1_pins_sleep>; }; &usb2_phy2 { status = "okay"; }; &usb2 { dr_mode = "host"; status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&usb2_pins_default>; pinctrl-1 = <&usb2_pins_sleep>; }; &mac { slaves = <1>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&cpsw_default>; pinctrl-1 = <&cpsw_sleep>; status = "okay"; }; &davinci_mdio { pinctrl-names = "default", "sleep"; pinctrl-0 = <&davinci_mdio_default>; pinctrl-1 = <&davinci_mdio_sleep>; status = "okay"; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "rgmii"; }; &elm { status = "okay"; }; &gpmc { /* * When enabling GPMC, disable eMMC and set * SelEMMCorNAND to output-low */ status = "disabled"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&nand_flash_x8_default>; pinctrl-1 = <&nand_flash_x8_sleep>; ranges = <0 0 0x08000000 0x01000000>; /* CS0 space. Min partition = 16MB */ nand@0,0 { compatible = "ti,omap2-nand"; reg = <0 0 4>; /* device IO registers */ interrupt-parent = <&gpmc>; interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ <1 IRQ_TYPE_NONE>; /* termcount */ rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */ ti,nand-ecc-opt = "bch16"; ti,elm-id = <&elm>; nand-bus-width = <8>; gpmc,device-width = <1>; gpmc,sync-clk-ps = <0>; gpmc,cs-on-ns = <0>; gpmc,cs-rd-off-ns = <40>; gpmc,cs-wr-off-ns = <40>; gpmc,adv-on-ns = <0>; gpmc,adv-rd-off-ns = <25>; gpmc,adv-wr-off-ns = <25>; gpmc,we-on-ns = <0>; gpmc,we-off-ns = <20>; gpmc,oe-on-ns = <3>; gpmc,oe-off-ns = <30>; gpmc,access-ns = <30>; gpmc,rd-cycle-ns = <40>; gpmc,wr-cycle-ns = <40>; gpmc,bus-turnaround-ns = <0>; gpmc,cycle2cycle-delay-ns = <0>; gpmc,clk-activation-ns = <0>; gpmc,wr-access-ns = <40>; gpmc,wr-data-mux-bus-ns = <0>; /* MTD partition table */ /* All SPL-* partitions are sized to minimal length * which can be independently programmable. For * NAND flash this is equal to size of erase-block */ #address-cells = <1>; #size-cells = <1>; partition@0 { label = "NAND.SPL"; reg = <0x00000000 0x00040000>; }; partition@1 { label = "NAND.SPL.backup1"; reg = <0x00040000 0x00040000>; }; partition@2 { label = "NAND.SPL.backup2"; reg = <0x00080000 0x00040000>; }; partition@3 { label = "NAND.SPL.backup3"; reg = <0x000c0000 0x00040000>; }; partition@4 { label = "NAND.u-boot-spl-os"; reg = <0x00100000 0x00080000>; }; partition@5 { label = "NAND.u-boot"; reg = <0x00180000 0x00100000>; }; partition@6 { label = "NAND.u-boot-env"; reg = <0x00280000 0x00040000>; }; partition@7 { label = "NAND.u-boot-env.backup1"; reg = <0x002c0000 0x00040000>; }; partition@8 { label = "NAND.kernel"; reg = <0x00300000 0x00700000>; }; partition@9 { label = "NAND.file-system"; reg = <0x00a00000 0x1f600000>; }; }; }; &uart0 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&uart0_pins_default>; pinctrl-1 = <&uart0_pins_sleep>; }; &dss { status = "ok"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&dss_pins_default>; pinctrl-1 = <&dss_pins_sleep>; port { dpi_out: endpoint@0 { remote-endpoint = <&lcd_in>; data-lines = <24>; }; }; }; &dcan0 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&dcan0_default>; pinctrl-1 = <&dcan0_sleep>; status = "okay"; }; &dcan1 { pinctrl-names = "default", "sleep"; pinctrl-0 = <&dcan1_default>; pinctrl-1 = <&dcan1_sleep>; status = "okay"; }; &vpfe0 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&vpfe0_pins_default>; pinctrl-1 = <&vpfe0_pins_sleep>; port { vpfe0_ep: endpoint { remote-endpoint = <&ov2659_0>; ti,am437x-vpfe-interface = <0>; bus-width = <8>; hsync-active = <0>; vsync-active = <0>; }; }; }; &vpfe1 { status = "okay"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&vpfe1_pins_default>; pinctrl-1 = <&vpfe1_pins_sleep>; port { vpfe1_ep: endpoint { remote-endpoint = <&ov2659_1>; ti,am437x-vpfe-interface = <0>; bus-width = <8>; hsync-active = <0>; vsync-active = <0>; }; }; }; &mcasp1 { #sound-dai-cells = <0>; pinctrl-names = "default", "sleep"; pinctrl-0 = <&mcasp1_pins>; pinctrl-1 = <&mcasp1_sleep_pins>; status = "disable"; op-mode = <0>; /* MCASP_IIS_MODE */ tdm-slots = <2>; /* 4 serializers */ serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ 0 0 1 2 >; tx-num-evt = <32>; rx-num-evt = <32>; }; &rtc { clocks = <&clk_32k_rtc>, <&clk_32768_ck>; clock-names = "ext-clk", "int-clk"; system-power-controller; status = "okay"; }; &wkup_m3_ipc { ti,set-io-isolation; ti,scale-data-fw = "am43x-evm-scale-data.bin"; }; &sgx { status = "okay"; }; &cpu { cpu0-supply = <&dcdc2>; /* Operating frequencies */ /* Defaults specified in arch/arm/mach-omap2/opp43xx_data.c */ /* operating-points = <300000 950000>, <600000 1100000>, <720000 1200000>, <800000 1260000>, <1000000 1330000>; */ };
