HI
we would like to know when the WL18xx do MIMO/SISO/ antenna diversity (function b/g/n, PA MIMO, …) ?
In particular, our wish is to understand what the MRC mode does, how to activate it and how to check that it is activated.
A priori in MRC mode the Wifi client receives on 2 antennas and by reconstructed processing the signal, but this mode does not act on the emission.
If this mode is enabled on the module (ht.mode = 1 -> SISO40 or ht.mode = 2 -> SISO20; phy.number_of_assembled_ant2_4 = 2 -> MRC; wl18xx.phy.spare0 = 0) only on antenna 1 and should listen on antennas 1 and 2.
Is there a mode that allows in wifi mode b / g to use in automatic transmission the antenna 1 or the antenna 2 according to the level of reception of this one?
Thanks for your support
Carl
