Other Parts Discussed in Thread: WL1831
Dear TI engineer:
My customer use WL1831 for BT Phone application. It will happen communication noise probability.
In the BT pcm mode ,when WL1831 is host, the noise problem will no happened, but when WL1831 is slave, the noise happened probability.
The datasheet has BT PCM Clock mismatch section, but not very detail. Can you help to explain when and how the mismatch may happen, and how to avoid?
