Can somebody explain this?
" The device is FCC, IC, ETSI/CE, and TELEC certified for AP and client"
Can the WL1835MOD be used in a mobile unit (ie; tablet)?
thanks,
Tom
thanks,
Tom
??any plans for portable, or what other device do you recommend for portable??
thanks for the info, from the verbiage,
the WL18XXMOD is certified for Mobile but NOT Portable (see below).
How To certify Host End Products
Hi Tom,
We are certified for operation > 20CM. If you operate < 20CM you will need to do SAR testing. So the module can be used for portable devices. For FCC/IC we have a process that allows you to reuse the data then do the delta testing required. You will need your own FCC/IC ID for this, but allows ruse of the majority of the data for certification. The form is attached.
7180.WiLink_Cert_Form_081717.pdf
thanks,
Riz
