Other Parts Discussed in Thread: Z-STACK
we have successfully connected a CC2630 to a custom board. Using the IAR EWARM we can:
* erase the memory;
* flash the Z-Stack sample applications;
* use the debugger (behaviour NOT consistent); and
* join a coordinator and exchange messages (retrieve active endpoints, simple descriptor, node descriptor).
Unfortunately every time we change the code we have to completely erase the flash and download the ZStackCore and the application (e.g. SampleSwitch) to the device. Otherwise the device gets stuck in the ICall_createRemoteTasks() call. Powering on/off the device does not help.
We haven't made any significant changes to the sample source code, which is actually written for the SmartRF06 development board (we changed the target to 'TexasInstruments CC2630F128'). The board we are using does not have the switches, LEDs, LCD, etc.
We are programming and debugging the device using an XDS100-V3 debug probe.
Any ideas why we have difficulties re-programming and debugging the device?
Thanks in advance
Todor
