Starterware/TIDC-CC2650STK-SENSORTAG: need help sensorTag with Z-Stack Home Sample Application User’s Guide
Part Number: TIDC-CC2650STK-SENSORTAG
Other Parts Discussed in Thread: Z-STACK, CC2650, SYSBIOS, TIMAC, CC2650STK, CC2531, CC2531EMK
Tool/software: Starterware
I have SensorTag with debug devpack
Useing IAR, Reference Z-Stack Home Sample Application User’s Guide.pdf
But in progressing, error heppend
Error while running "c:/ti/xdctools_3_32_00_06_core/xs"
i just want setting Development environment, use zigbee network.
sorry about my Inexperienced English Proficiency
  • What IAR version do you use?
  • useing 7.40 and 7.80
    first, i use 7.80 and change to 7.40, error messege : project file's options were broken and can't open project
    so i reuse 7.80
  • You should use IAR EWARM 7.40.2 to build SensorTag examples in Z-Stack Home 1.2.2a.
  • i use 7.40.2 and before download example to sensorTag,i make project
    but I got an error.
    Building configuration: SampleSwitch - SmartRF06
    Updating build tree...
    Performing Pre-Build Action
    --xdcpath="c:/ti/tirtos_cc13xx_cc26xx_2_21_00_06/packages;c:/ti/tirtos_cc13xx_cc26xx_2_21_00_06/products/tidrivers_cc13xx_cc26xx_2_21_00_04/packages;c:/ti/tirtos_cc13xx_cc26xx_2_21_00_06/products/bios_6_46_01_37/packages;
    c:/ti/tirtos_cc13xx_cc26xx_2_21_00_06/products/uia_2_01_00_01/packages" iar.tools.configuro -c "C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\arm" --cc "C:\Program Files (x86)\IAR Systems\Embedded Workbench
    7.2\arm\bin\iccarm.exe" --device "CC2650F128" --compileOptions "-D ZSTACK_MANUAL_START -D ZCL_READ -D ZCL_WRITE -D ZCL_BASIC -D ZCL_ON_OFF -D ZCL_IDENTIFY -D ZCL_EZMODE -D xZCL_GROUPS -D
    xZCL_SCENES -D ZCL_STANDALONE -D ZG_SECURE_ENABLED -D ewarm -D USE_ICALL -D HEAPMGR_SIZE=4096 -D ICALL_HOOK_ABORT_FUNC=halAssertHandler -D xdc_runtime_Log_DISABLE_ALL -D
    xdc_runtime_Assert_DISABLE_ALL -D MODULE_CC26XX_7X7 -D TI_DRIVERS_LCD_INCLUDED --diag_suppress Pa050 -o C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\
    SmartRF06\Obj\ --debug --endian=little --cpu=Cortex-M3 -f C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\configPkg\compiler.opt.defs -f C:\ti\simplelink\
    zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\Core\Thread\CC26xx\Config\coreEndDevice.cfg -e --fpu=None --dlib_config \"C:\Program Files (x86)\IAR Systems\Embedded Workbench
    7.2\arm\INC\c\DLib_Config_Normal.h\" -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\.\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\
    SampleSwitch\CC26xx\..\..\Source\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\common\CC26xx\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\
    HomeAutomation\SampleSwitch\CC26xx\..\..\..\common\CC26xx\appport\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\common\CC26xx\SmartRF06\ -I C:\ti\simplelink\
    zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\applib\heap\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\
    ..\..\..\..\Components\mac\include\cc26xx\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\hal\include\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\
    Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\hal\target\_common\cc26xx\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\
    Components\hal\target\CC2650\rom\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\hal\target\CC2650TIRTOS\ -I C:\ti\simplelink\
    zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\icall\include\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\
    ..\..\..\..\Components\osal\include\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\services\nv\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\
    zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\services\nv\cc26xx\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\services\
    saddr\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\stack\icall\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\
    SampleSwitch\CC26xx\..\..\..\..\..\Components\stack\icall\client\ -I C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Components\stack\zcl\ -I C:\ti\
    tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829/\ -I C:\ti\tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829/inc\ -I C:\ti\tirtos_simplelink_2_11_01_09\products\cc26xxware_2_20_06_14829/driverlib\
    -Ohz" --linkOptions "-o C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\SmartRF06\Exe\SampleSwitch.out --config_def CC2650=1 --config_def USE_SYSBIOS_IN_ROM=1 --map
    C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\SmartRF06\List\SampleSwitch.map --config C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\
    SampleSwitch\CC26xx\cc26xx_app.icf --keep __vector_table -f C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\configPkg\linker.cmd -f C:\ti\simplelink\
    zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\Core\Thread\CC26xx\Config\coreEndDevice.xcl --semihosting C:\ti\tirtos_simplelink_2_11_01_09\products\
    cc26xxware_2_20_06_14829/driverlib/bin/iar/driverlib.lib C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\..\..\..\..\..\Projects\common\TIMAC_ROM_Release\03282014\
    timac_rom_PATCH.symbols --entry __iar_program_start --vfe" --profile release --projFile "C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SampleSwitch\CC26xx\SampleSwitch.ewp"
    Using RTSC configuration file: C:/ti/simplelink/zstack_home_1_02_02a_44539/Projects/zstack/HomeAutomation/SampleSwitch/CC26xx/app.cfg...
    configuring app.xrm3 from package/cfg/app_prm3.cfg ...
    js: "C:/ti/simplelink/zstack_home_1_02_02a_44539/Projects/zstack/HomeAutomation/SampleSwitch/CC26xx/app.cfg", line 42: XDC runtime error: ti.sysbios.family.arm.cc26xx.Power: no property named 'standbyPolicy'
    "./package/cfg/app_prm3.cfg", line 175
    xdctools_3_32_00_06_core\gmake.exe: *** [package/cfg/app_prm3.xdl] Error 1
    js: "C:/ti/tirtos_cc13xx_cc26xx_2_21_00_06/products/bios_6_46_01_37/packages/iar/tools/configuro/Main.xs", line 133: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    Total number of errors: 1
    Total number of warnings: 0
    like this so many error and i don't know why this error
  • Try to reintall Z-Stack Home 1.2.2a and build again.
  • i reinstalled z-stack home 1.2.2a and build again
    but i got an same error
  • If you have "tirtos_cc13xx_cc26xx_2_21_00_06 (global)" in Configure Custom Argument Variables, try to disable it and build again.
  • Thank you. build succeeded.
    I have another question.
    i don't have SmartRF06board.
    so is there another way to check sensorTag zigbee signal?
  • What do you mean " check sensorTag zigbee signal"?
  • i want check that works well without SmartRF06board.
    My goal is to build a development environment using ZigBee and sensor Tag.
  • If you mean to run Z-Stack Home 1.2.2a example on CC2650STK, there is a example named SensorTag which is dedicated for CC2650STK.
  • i have just SimpleLink SensorTag Debugger DevPack with sensorTag.
    can i run a example named SensorTag?
  • Yes, it's for SensorTag Debugger DevPack with sensorTag.
  • Thank you. I will write if I need another help.
  • You are welcome.
  • A new error has occurred.
    I opened SensorTag project and download and debug
    Thu Feb 16, 2017 11:30:23: Fatal error: No debug probe found connected to the USB port Session aborted!
    What I can do?
  • You have to change debug probe to XDS110 instead of XDS100v3.
  • It was resolved. I clicked download and debug.
    However, there is a new problem as above.
  • What's the information in the Debug Log window?
  • Thu Feb 16, 2017 11:57:21: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\debugger\TexasInstruments\CC26xx.dmac
    Thu Feb 16, 2017 11:57:21: Loaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\flashloader\TexasInstruments\FlashCC26xx.mac
    Thu Feb 16, 2017 11:57:22: Initial reset was performed
    Thu Feb 16, 2017 11:57:22: TI XDS ARM, device revision: 0x00000001, big endian: false, cache: false, board revision: 0x00000000, driver revision: 0x0B020200
    Thu Feb 16, 2017 11:57:22: Watchdog disabled
    Thu Feb 16, 2017 11:57:23: 544 bytes downloaded (11.30 Kbytes/sec)
    Thu Feb 16, 2017 11:57:23: Loaded debugee: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\flashloader\TexasInstruments\FlashCC26xxRAM20.out
    Thu Feb 16, 2017 11:57:23: Target reset
    Thu Feb 16, 2017 11:57:29: Unloaded macro file: C:\Program Files\IAR Systems\Embedded Workbench 7.2\arm\config\flashloader\TexasInstruments\FlashCC26xx.mac
    Thu Feb 16, 2017 11:57:29: Downloaded C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SensorTag\CC2650\SensorTag\Exe\SensorTag.out to flash memory.
    Thu Feb 16, 2017 11:57:31: Watchdog disabled
    Thu Feb 16, 2017 11:57:32: 36056 bytes downloaded into FLASH (3.89 Kbytes/sec)
    Thu Feb 16, 2017 11:57:32: Loaded debugee: C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SensorTag\CC2650\SensorTag\Exe\SensorTag.out
    Thu Feb 16, 2017 11:57:32: Target reset
    Thu Feb 16, 2017 11:57:33: Failed to load extra image: C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\HomeAutomation\SensorTag\CC2650\..\..\..\..\..\Projects\zstack\Core\Thread\CC26xx\EndDevice\Exe\
    ZStackCoreEndDevice.out
    This is it.
  • sorry,my project file was wrong.
    I downloaded the project file again and slove it.
  • It's good to know you find the problem and solve it.
  • I have a new question.
    Is there a way to output characters to the PC screen using serial communication using PuTTY?
  • Yes, you can add UART driver to do it.
  • How can i add UART driver?
  • You can try to refer to CC26xx ZNP project.
  • Thank you very much. I'll try.
  • You are welcome.
  • Can I get some help?
    I read the znp guide, but I do not understand it.
    Can i get some advice on how to print characters to putty on pc? or is there anything I can refer to?
  • Should I have a CC2531 USB dongle?
  • If you don't have CC2531 USB dongle, you can use CC2650STK and CC-DEVPACK-DEBUGGER as ZNP which you can refer to sunmaysky.blogspot.tw/.../how-to-use-sensortag-cc2650stk-with-cc.html
  • What is your COM port settings in ZTOOL?
  • I set it as above.
    and UART port is com15
  • Do you change UART pins in board file when you build ZNP hex and download it to your CC2650STK?
  • Yes, it is fixed as above.
  • Try to set CTS/RTS pins to unused.
  • I fixed it as above but it still does not work
  • Are you sure you modify Board.h under (C:\ti\tirtos_simplelink_2_11_01_09\packages\ti\boards\SRF06EB\CC2650EM_7ID?
  • Can you take a picture to show me how you connect your CC2650STK to your desktop?
  • It is connected like the picture above.
    I knew I would reconnect the 3rd step of the site to CC-DEVPACK-DEBUGGER.
  • Try to remove battery from CC2650STK and test again.
  • Ztool still can not catch it.
    I did the znp project. Is not this right?(in C:\ti\simplelink\zstack_home_1_02_02a_44539\Projects\zstack\ZNP\CC26xx)
  • Can you attach your ZNP hex file? I can test it when I can access to my CC2650STK and CC-DEVPACK-DEBUGGER.
  • 2210.znp_coordinator_pro_secure_linkkeyjoin.zip
    I'm sorry I'm late.
    I tried it with my friend 's pc and ztool recognized it.
    His pc is Windows 10 and my pc is Windows 7.
    Could this be a problem?
  • Your hex doesn't work on my CC2650STK+CC-DEVPACK-DEBUUGER too. I attach mine which works on my CC2650STK+CC-DEVPACK-DEBUUGER for your reference.
    3438.znp_coordinator_pro_secure_linkkeyjoin.zip
  • Thank you. Ztool is connected.
  • You are welcome and it's good to know it works.
