Other Parts Discussed in Thread: CC2650, Z-STACK,
in my setup, i used one CC2650 launchpad with ZNP coordinator firmware and another CC2650 launchpad with ZNP router firmware. i am using zstack_home_1_02_02a_44539 libraries. I also placed a zigbee packet sniffer with CC2531 dongle to monitor packets.
i use PC to run ztool with attached scripts inside 7z file ACTIVE_EP_REQ_issue.7zto make coordinator and router.
After successful connection. i issued ACTIVE_EP_REQ from ztool of coordinator. i can get back response properly.
then i turned off the router by removing power of CC2650 launchpad, which configured as router. then i issued ACTIVE_EP_REQ command again from ztool of coordinator.
in packet sniffer i see 8 times coordinator send request, may i know why 8 times, instead of 1?
if i want to make 1 instead of 8, what i need to change.0250.ACTIVE_EP_REQ_issue.7z
