Hi community members,
For LAUNCHXL-CC1352P-2 example projects, TX power will be diminished significantly below the expected output unless PIN_init(BoardGpioInitTable); from the main function of main.c is replaced with the following:
#if defined(CC13X2R1_LAUNCHXL) && !defined(NO_CC1312R1_SUPPORT) && !defined(NO_CC1352P1_SUPPORT) CC13X2R1_LAUNCHXL_Pin_init(); #else PIN_init(BoardGpioInitTable); #endif
This fix applies to the SimpleLink Zigbee SDK Plugin v2.20 and will be fixed in time for the v2.30 release.
Regards, Ryan
