Suitable charger for 5.6 Ah Li-ion battery, charge voltage 4.2V
Other Parts Discussed in Thread: BQ25616, BQ24166, BQ25606
Can anyone recommend a best choice for charging - 5.6 Ah Li-ion battery, charge voltage 4.2V?
I've found the BQ24166RGET so far, and also found availability problems with many charger ICs.
The circuit:
  • Compact, ideally less than 20 pins though the BQ24166RGET is very compact anyway
  • Battery voltage is 3.65V and charging voltage is 4.2V (+- 0.9%)
  • Higher maximum charge current than 2.5A if possible
  • Low internal leakage current
  • Supply uninterruptable by Battery or Charging supply
  • Input from battery thermistor not required
  • Output current from battery > 1A
