Other Parts Discussed in Thread: TPS25947, TPS25948, TPS25983
I have a question regarding the BQ25723 charge controller.
I plan to make it so that it has the option of charging from an adapter or USB-C PD, switching between the two can be done in the software depending on the customer's needs.
Is it possible if I use the PD to power my system from the battery that I use the adapter or the UCB-C PD input as a support to provide enough power?
I plan to use 2 different chips for PD like TPS25750D for input and output as the custommer needs 2 different plugs for input and output in my system.
Thank you!
