Other Parts Discussed in Thread: BQ51013B, BQ500212A
What are common symptoms of a poorly tuned Rx coil?
I am using a bq51013b receiver design based on the EVM and believe that my issue is most likely an improperly tuned Rx coil but I want to confirm. My OUT pin remains at 0 volts aside from some noise during pings and my RECT pin has a periodic wave form. Communication is never established. I am using a bq500212a based transmitter design the follows the EVM very closely. A problem could lie on that end, but the pings are at 175khz and 0-5V so my confidence for the Tx side is higher. Plots of AC1, AC2, and RECT of the bq51013b as well as the bq500212a ping are below.
Also, what procedure does TI follow to calculate the Ls and Ls' of different coils?
Both the bq51013b datasheet and WPC specification leave a bit to be desired in terms of specifics. I know calculating inductance in neither difficult nor challenging, but knowing that I am following the exact procedure as those who designed the part I am using will give me more confidence in my results.
Thank you very much for your time.
AC1
AC2
REC
Tx Ping Length (no secondary present)
Tx Ping Freq (no secondary present)
