LM25066A: Backfeeding voltage to Series Pass FET
Part Number: LM25066A
Referencing the "Typical Application Schematic" in the LM25066A datasheet:
I would like to know if applying voltage to the output (Vout) with no voltage on the input (Vin) will damage the LM25066A.  Doing this would create a voltage drop across the parasitic body diode in the series pass FET, and this voltage would be applied from the OUT pin to the SENSE and VIN pins.  There are no ratings in the datasheet regarding OUT to SENSE or OUT to VIN.
