Other Parts Discussed in Thread: TPS62065
Hi Sir,
For TLV62569, the VIL definition is min = 0.4V, and this definition is different from other IC that they will define VIL as max.
for example, TPS62065, the VIL of EN is 0.4V, and it was defined on the max value while TPS62569 put 0.4V on min value.
Could you help to advise why TPS62569 use a different way to define the VIL?
Patrick
