Part Number: TPS22910A
Other Parts Discussed in Thread: TPS22917, TPS22916,
I'm planning to use TPS22910A and TPS22913B load switch for one of my battery operated circuit.
The switch is just used to connect battery output to a resistor divider network ( battery ---TPS22910A/TPS22913B----- Resistor divider). Switch is enabled by Microcontroller GPIO.
1. Do I need to still connect an output capacitor ( C load) ?
2. Data sheet says output capacitor as optional. What is the significance of the same ?
3. What slew rate will be the switch working with no output capacitor connected ?
4. My load current is only 12-15 Micro amperes.
Anil
