CC2652R: Converting .out to .bin file
Part Number: CC2652R
Hello Guys,
Good day.
Our customer built ble5_host_test_cc26x2r1lp_ticlang_app.out from the BLE5 host test demo application for CC2652R. This is RTOS.
What are the steps to convert this into .bin file?
He changed this line:
<GCC_TOOLCHAIN_PATH>/bin/arm-none-eabi-objcopy -O binary <application>.out <application>.bin
to
${CCS_UTILS_DIR}/bin/gnake -o binary ${ProjName}.out ${ProjName}.bin
but is unsuccessful.
Thanks and regards,
Art
  • Hi Art,
    Please have them refer to the following E2E post or ask the Code Composer Studio Forum if they continue to encounter difficulties.
    Ryan
  • Hello Ryan,
    Good day.
    The customer used this "${​CCS_INSTALL_ROOT}​/utils/tiobj2bin/tiobj2bin.bat ${​BuildArtifactFileName}​ ${​BuildArtifactFileBaseName}​.bin ${​CG_TOOL_ROOT}​/bin/armofd.exe ${​CG_TOOL_ROOT}​/bin/armhex.exe ${​CCS_INSTALL_ROOT}​/utils/tiobj2bin/mkhex4bin.exe"
    and got this error messages.
    ​/utils/tiobj2bin/tiobj2bin.bat ​ ​.bin ​/bin/armofd.exe ​/bin/armhex.exe ​/utils/tiobj2bin/mkhex4bin.exe
    makefile:221: recipe for target 'post-build' failed
    process_begin: CreateProcess(NULL, ​/utils/tiobj2bin/tiobj2bin.bat ​ ​.bin ​/bin/armofd.exe ​/bin/armhex.exe ​/utils/tiobj2bin/mkhex4bin.exe, ...) failed.
    Thanks and regards,
    Art
  • The post-build command needs quotation marks surrounding each parameter.  Here is a somewhat similar E2E post.  I was able to generate a binary image in the output folder by using the following on the CCS compiler:
    "${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin.bat" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd.exe" "${CG_TOOL_ROOT}/bin/armhex.exe" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin.exe"
    Unfortunately, I expect issues will be encountered using Tiobj2bin with TI-CLANG.
    Ryan
