Part Number: SIMPLELINK-CC13X2-26X2-SDK
Other Parts Discussed in Thread: SIMPLELINK-CC13XX-CC26XX-SDK, CC2530, CC2531, Z-STACK, CC2652R
After executing some interpan commands, my ZNP firmware based on SIMPLELINK-CC13XX-CC26XX-SDK_5.30.00.56 crashes. After this the ZNP is not responding anymore and has to be replugged to work again. This also happens with older SDKs (I've tested with 4.30, 4.40 and 5.10).
The same command sequence does not make my firmware for the CC2531 and CC2530 crash (Z-stack home 1.2), therefore I believe this is a bug in the simplelink sdk.
Zigbee2MQTT log containing the execute z-stack commands:
Zigbee2MQTT:debug 2021-11-15 18:31:21: Received MQTT message on 'zigbee2mqtt/bridge/request/touchlink/scan' with data '{"transaction":"39mfd-2","value":true}'
Zigbee2MQTT:info 2021-11-15 18:31:21: Start Touchlink scan
zigbee-herdsman:controller:touchlink Set InterPAN channel to '11' +15s
zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - interPanCtl - {"cmd":1,"data":[11]} +15s
zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,36,16,1,11,60] +15s
zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,16,0,117] +15s
zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,16,0,117] +0ms
zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 16 - [0] - 117 +0ms
zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - interPanCtl - {"status":0} +15s
zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [] +1ms
zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000ffff","destendpoint":254,"dstpanid":65535,"srcendpoint":12,"clusterid":4096,"transid":18,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[17,0,0,163,155,172,203,4,18]}} +4ms
zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,29,36,2,2,255,255,0,0,0,0,0,0,254,255,255,12,0,16,18,0,30,9,0,17,0,0,163,155,172,203,4,18,134] +4ms
zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,2,0,103] +6ms
zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,1,100,2,0,103] +0ms
zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 1 - 3 - 4 - 2 - [0] - 103 +0ms
zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequestExt - {"status":0} +7ms
zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [] +0ms
zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,12,18,217] +3ms
zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,12,18,217] +0ms
zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,12,18] - 217 +0ms
zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":12,"transid":18} +16s
zigbee-herdsman:controller:touchlink Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms' +512ms
zigbee-herdsman:controller:touchlink Set InterPAN channel to '15' +0ms
zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - interPanCtl - {"cmd":1,"data":[15]} +507ms
zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,36,16,1,15,56] +508ms
zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,1,100,16,0,117] +501ms
zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - interPanCtl - {"status":0} +506ms
zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - dataRequestExt - {"dstaddrmode":2,"dstaddr":"0x000000000000ffff","destendpoint":254,"dstpanid":65535,"srcendpoint":12,"clusterid":4096,"transid":19,"options":0,"radius":30,"len":9,"data":{"type":"Buffer","data":[17,0,0,38,82,31,81,4,18]}} +5ms
zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,29,36,2,2,255,255,0,0,0,0,0,0,254,255,255,12,0,16,19,0,30,9,0,17,0,0,38,82,31,81,4,18,226] +4ms
zigbee-herdsman:adapter:zStack:znp:SRSP <-- AF - dataRequestExt - {"status":0} +6ms
zigbee-herdsman:adapter:zStack:unpi:parser <-- [254,3,68,128,0,12,19,216] +4ms
zigbee-herdsman:adapter:zStack:unpi:parser --- parseNext [254,3,68,128,0,12,19,216] +0ms
zigbee-herdsman:adapter:zStack:unpi:parser --> parsed 3 - 2 - 4 - 128 - [0,12,19] - 216 +0ms
zigbee-herdsman:adapter:zStack:znp:AREQ <-- AF - dataConfirm - {"status":0,"endpoint":12,"transid":19} +513ms
zigbee-herdsman:controller:touchlink Set InterPAN channel to '20' +1ms
zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - interPanCtl - {"cmd":1,"data":[20]} +508ms
zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,2,36,16,1,20,35] +508ms
zigbee-herdsman:controller:touchlink Restore InterPAN channel +6s
zigbee-herdsman:adapter:zStack:znp:SREQ --> AF - interPanCtl - {"cmd":0,"data":[]} +6s
zigbee-herdsman:adapter:zStack:unpi:writer --> frame [254,1,36,16,0,53] +6s
Zigbee2MQTT:error 2021-11-15 18:31:34: Request 'zigbee2mqtt/bridge/request/touchlink/scan' failed with error: 'SRSP - AF - interPanCtl after 6000ms'
Zigbee2MQTT:debug 2021-11-15 18:31:34: Error: SRSP - AF - interPanCtl after 6000ms
at Timeout._onTimeout (/Users/koenkk/Git/zigbee2mqtt/node_modules/zigbee-herdsman/src/utils/waitress.ts:64:35)
at listOnTimeout (node:internal/timers:557:17)
at processTimers (node:internal/timers:500:7)
Zigbee2MQTT:info 2021-11-15 18:31:34: MQTT publish: topic 'zigbee2mqtt/bridge/response/touchlink/scan', payload '{"data":{},"error":"SRSP - AF - interPanCtl after 6000ms","status":"error","transaction":"39mfd-2"}'
