LAUNCHXL-CC26X2R1: How can I use Power_shutdown(0, 0); and PINCC26XX_setWakeup();..!
Part Number: LAUNCHXL-CC26X2R1
Other Parts Discussed in Thread: SIMPLELINK-CC13XX-CC26XX-SDK
Hello Team,
Currently I am working on simple central project.  In this I have added a function void SimpleCentral_performPeriodicTask(void);( reference by SimplePeripheral_performPeriodicTask ), now I have to use Power_shutdown(0, 0); and for the wake I want to 3 GPIO(button) which already used for the other data sending function. how can I implement this please suggest me..!
Ashutosh Singh
  • Hello Ashutosh,
    Please refer to this similar E2E thread.  It should be possible to continue using PinCC26XX_setWakeup until the PIN.h Driver is deprecated in SIMPLELINK-CC13XX-CC26XX-SDK v6.20 (after Q2 of 2022).
    Ryan
  • Hello Ryan,
    Thank you for your replay. but I am facing one another issue in which I am using this array to the set the PIN_Config gpioPinTable[] but I am giving this array as an input to function PIN_open but function is returning NULL value and the task_exit.
    So my problem is why the function PIN_open is returning NULL even though the pin CONFIG_PIN_BTN1 is present in pin list
    please help me out for the above the issue
    Ashutosh
    static PIN_State gpioPinState;
    /* GPIO Pin Handle */
    static PIN_Handle gpioPinHandle;
    PIN_Config gpioPinTable[] = {
    CONFIG_PIN_BTN1 | PIN_INPUT_EN | PIN_NOPULL | PINCC26XX_WAKEUP_POSEDGE,
    PIN_TERMINATE
    gpioPinHandle = PIN_open(&gpioPinState, gpioPinTable);
    if(gpioPinHandle==NULL)
    /*Log_error0("Error initializing motion sensor pins");*/
    Task_exit();
  • The issue is most likely pin initialization as highlighted in the prior E2E thread.
    #define CONFIG_PIN_COUNT 4
    const PIN_Config BoardGpioInitTable[CONFIG_PIN_COUNT + 1] = {
        /* LaunchPad Button BTN-1 (Left) (DIO13) */
        CONFIG_PIN_BUTTON_0 | PIN_INPUT_EN | PIN_NOPULL | PIN_IRQ_DIS,
        /* LaunchPad Button BTN-2 (Right) (DIO14) */
        CONFIG_PIN_BUTTON_1 | PIN_INPUT_EN | PIN_NOPULL | PIN_IRQ_DIS,
        /* LaunchPad LED Red (DIO6) */
        CONFIG_PIN_LED_0 | PIN_INPUT_EN | PIN_NOPULL | PIN_IRQ_DIS,
        /* LaunchPad LED Green (DIO7) */
        CONFIG_PIN_LED_1 | PIN_INPUT_EN | PIN_NOPULL | PIN_IRQ_DIS,
        PIN_TERMINATE
    const PINCC26XX_HWAttrs PINCC26XX_hwAttrs = {
        .intPriority = (~0),
        .swiPriority = 0
        /* ==== /ti/drivers/PIN initialization ==== */
        if (PIN_init(BoardGpioInitTable) != PIN_SUCCESS) {
            /* Error with PIN_init */
            while (1);
    As an example, below is the pinShutdown.c example from the v5.20 SDK which has been modified to operate in place of a empty v5.40 project (you should exclude the main_tirtos.c from building as main is included in the below c file):
     * Copyright (c) 2015-2019, Texas Instruments Incorporated
     * All rights reserved.
     * Redistribution and use in source and binary forms, with or without
     * modification, are permitted provided that the following conditions
     * are met:
     * *  Redistributions of source code must retain the above copyright
     * *  Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the distribution.
     * *  Neither the name of Texas Instruments Incorporated nor the names of
     * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
     * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
     * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
     * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
     * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
     * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
     * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
     * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
     * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
     * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
     *  ======== pinShutdown.c ========
    #include <stdbool.h>
    #include <ti/sysbios/BIOS.h>
    #include <ti/sysbios/knl/Clock.h>
    #include <ti/sysbios/knl/Task.h>
    #include <ti/sysbios/knl/Semaphore.h>
    #include <ti/drivers/Power.h>
    #include <ti/drivers/PIN.h>
    #include <ti/drivers/pin/PINCC26XX.h>
    #include <ti/devices/DeviceFamily.h>
    #include DeviceFamily_constructPath(inc/hw_prcm.h)
    #include DeviceFamily_constructPath(driverlib/sys_ctrl.h)
    /* TI-Drivers Configuration */
    #include "ti_drivers_config.h"
    #define CONFIG_PIN_BUTTON_0                   0x0000000d
    #define CONFIG_PIN_BUTTON_1                   0x0000000e
    #define CONFIG_PIN_LED_0                   0x00000006
    #define CONFIG_PIN_LED_1                   0x00000007
    /* Task and tast stack */
    Task_Struct myTask;
    Char myTaskStack[512];
    /* Semaphore used to gate for shutdown */
    Semaphore_Struct shutdownSem;
    /* Clock used for debounce logic */
    Clock_Struct buttonClock;
    Clock_Handle hButtonClock;
    /* Pin driver handles */
    PIN_Handle hPins;
    PIN_Handle hButtons;
    /* LED pin state */
    PIN_State LedPinState;
    /* Button pin state */
    PIN_State buttonState;
    /* Flag to store whether we woke up from shutdown or not */
    bool isWakingFromShutdown;
    /* PIN_Id for active button (in debounce period) */
    PIN_Id activeButtonPinId;
    .swiPriority = 0
    /* Led pin table used when waking from reset*/
    PIN_Config LedPinTable[] = {
        CONFIG_PIN_LED_1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW  | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */
        CONFIG_PIN_LED_0 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially on */
        PIN_TERMINATE                                                    /* Terminate list */
    /* Led pin table used when waking from shutdown */
    PIN_Config LedPinTableSd[] = {
        CONFIG_PIN_LED_1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_HIGH | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially on */
        CONFIG_PIN_LED_0 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW  | PIN_PUSHPULL | PIN_DRVSTR_MAX, /* LED initially off */
    /* Wake-up Button pin table */
    PIN_Config ButtonTableWakeUp[] = {
        CONFIG_PIN_BUTTON_0 | PIN_INPUT_EN | PIN_PULLUP | PINCC26XX_WAKEUP_NEGEDGE,
    /* Shutdown Button pin table */
    PIN_Config ButtonTableShutdown[] = {
        CONFIG_PIN_BUTTON_1 | PIN_INPUT_EN | PIN_PULLUP | PIN_IRQ_NEGEDGE,
        PIN_TERMINATE
     *  @brief      Button clock callback
     *  Called when the debounce periode is over. Stopping the clock, toggling
     *  the device mode based on activeButtonPinId:
     *              CONFIG_PIN_BUTTON_1 will put the device in shutdown mode.
     *  Reenabling the interrupts and resetting the activeButtonPinId.
     *  @param      arg  argument (PIN_Handle) connected to the callback
    static void buttonClockCb(UArg arg) {
        PIN_Handle buttonHandle = (PIN_State *) arg;
        /* Stop the button clock */
        Clock_stop(hButtonClock);
        /* Check that there is active button for debounce logic*/
        if (activeButtonPinId != PIN_TERMINATE) {
            /* Debounce logic, only toggle if the button is still pushed (low) */
            if (!PIN_getInputValue(activeButtonPinId)) {
                /* Toggle LED based on the button pressed */
                switch (activeButtonPinId) {
                case CONFIG_PIN_BUTTON_1:
                    Semaphore_post(Semaphore_handle(&shutdownSem));
                    break;
                default:
                    /* Do nothing */
                    break;
        /* Re-enable interrupts to detect button release. */
        PIN_setConfig(buttonHandle, PIN_BM_IRQ, activeButtonPinId | PIN_IRQ_NEGEDGE);
        /* Set activeButtonPinId to none... */
        activeButtonPinId = PIN_TERMINATE;
     *  @brief      Button callback
     *  Initiates the debounce period by disabling interrupts, setting a timeout
     *  for the button clock callback and starting the button clock.
     *  Sets the activeButtonPinId.
     *  @param      handle PIN_Handle connected to the callback
     *  @param      pinId  PIN_Id of the DIO triggering the callback
     *  @return     none
    static void buttonCb(PIN_Handle handle, PIN_Id pinId) {
        /* Set current pinId to active */
        activeButtonPinId = pinId;
        /* Disable interrupts during debounce */
        PIN_setConfig(handle, PIN_BM_IRQ, activeButtonPinId | PIN_IRQ_DIS);
        /* Set timeout 50 ms from now and re-start clock */
        Clock_setTimeout(hButtonClock, (50 * (1000 / Clock_tickPeriod)));
        Clock_start(hButtonClock);
     *  @brief      Task which runs when the device is active
     *  @param      UArg a0 : User argument that can be passed to the task
     *  @param      UArg a1 : User argument that can be passed to the task
     *  @return     none - Should never return
    static void taskFxn(UArg a0, UArg a1)
        /* If we are waking up from shutdown, we do something extra. */
        if (isWakingFromShutdown) {
            /* In this example we toggle LED1 */
            uint32_t sleepUs = 500000;
            Task_sleep(sleepUs / Clock_tickPeriod);
            PIN_setOutputValue(hPins, CONFIG_PIN_LED_1, 0);
            PIN_setOutputValue(hPins, CONFIG_PIN_LED_1, 1);
        /* Turn on LED0 to indicate active */
        PIN_setOutputValue(hPins, CONFIG_PIN_LED_0, 1);
        /* Pend on semaphore before going to shutdown */
        Semaphore_pend(Semaphore_handle(&shutdownSem), BIOS_WAIT_FOREVER);
        /* Turn off LED0 */
        PIN_setOutputValue(hPins, CONFIG_PIN_LED_0, 0);
        /* Configure DIO for wake up from shutdown */
        PINCC26XX_setWakeup(ButtonTableWakeUp);
        /* Go to shutdown */
        /* Should never get here, since shutdown will reset. */
        while (1);
     *  @brief      Application main entry point
     *  @param      none
     *  @return     int - Should never return
    int main(void)
         /* Locals */
        Task_Params taskParams;
        Semaphore_Params semParams;
        /* Get the reason for reset.
         * On CC26X2, SysCtrlResetSourceGet() must be called before
         * PIN_init() because unlatching the IOs will clear the
         * wakeup from shutdown bit.
        uint32_t rSrc = SysCtrlResetSourceGet();
        while (1);
        /* Call driver init functions */
        Board_init();
        /* Do pin init before starting BIOS */
        /* If coming from shutdown, use special gpio table.*/
        if (rSrc == RSTSRC_WAKEUP_FROM_SHUTDOWN) {
            /* The shutdown table has LED1 on to ensure no glitch on the
             * output.
            isWakingFromShutdown = true;
            /* Open LED pins with shutdown table (LED1 on, LED0 off).
             * A separate PIN_config table is used to keep LED1 on.
            hPins = PIN_open(&LedPinState, LedPinTableSd);
        } else {
            /* When not waking from shutdown, use default init table. */
            isWakingFromShutdown = false;
            /* Open LED pins (LED1 off, LED0 on)*/
            hPins = PIN_open(&LedPinState, LedPinTable);
        /* Setup button pins with ISR */
        hButtons = PIN_open(&buttonState, ButtonTableShutdown);
        PIN_registerIntCb(hButtons, buttonCb);
        /* Construct clock for debounce */
        Clock_Params clockParams;
        Clock_Params_init(&clockParams);
        clockParams.arg = (UArg)hButtons;
        Clock_construct(&buttonClock, buttonClockCb, 0, &clockParams);
        hButtonClock = Clock_handle(&buttonClock);
        /* Configure task. */
        Task_Params_init(&taskParams);
        taskParams.stack = myTaskStack;
        taskParams.stackSize = sizeof(myTaskStack);
        Task_construct(&myTask, taskFxn, &taskParams, NULL);
        /* Configure shutdown semaphore. */
        Semaphore_Params_init(&semParams);
        semParams.mode = Semaphore_Mode_BINARY;
        Semaphore_construct(&shutdownSem, 0, &semParams);
        /* Start kernel. */
        BIOS_start();
        /* Should never get here, keep compiler happy */
        return (0);
    Ryan
  • Thank you Ryan, it's working good.
